Question about E-Machines eMachines Desktop PC
I down loaded drivers for emachine t2460 they are in another pc in zip folders, how do i get them on a cd to load them in the emachine t2460 windows xp
  • 490 Answers
Skip the CD and use a USB thumbdrive. They are cheap and can be purchased nearly anywhere now, including most groceries and hardware stores. You will find it a whole lot easier to work with as well.
Farmerbear at FixYa.com
Posted on Sep 17, 2010
Sm bus for emachines w3503 were do i get it
The term: SM Bus is the same as chipset driver. Your e-Machine came with restore CD's. You can run the restore CD to repair your system, you shouldn't loose any data repairing windows.
If your able to load windows, load the driver CD from e-Machine and re-install the chipset drivers.
Cheers!
Mike
Oct 17, 2009 | E-Machines W3503 PC Desktop
Tried recovering to original state from CD and now it will on start up in Safe mode.
It is possible that the CD you used did not load in all of the necessary drivers for the motherboard chip set and other hardware. If you do not have another disk, double check the one you have to see if it contains a seperate folder for drivers. If not, go to emachines.com and see if you can find driver downloads for your particular machine.
Oct 06, 2009 | E-Machines eMachines Desktop PC
I lost my cd to gigaware camara 25-157
if u need help with finding the gigaware drivers for the VGA web cam 25-157,then this will take you the like zip file that i created, what i did was copy the files off of the cd and created a zip folder with the original driver for it.
step 1
click on the link that will take you the Zshare to download the zip,make sure it down loads to you desktop.
(click on link)
http://www.zshare.net/download/6629694770298433/
step 2
Right click on the zip file that is on the desk top named Gigaware VGA Camera 25-157.zip and left like in the menu that pop up and left click on unzip or open.
Step 3
After opening or unziping the file you should see a icon the folder that says setup, clik on that and the rest is easy have any question the e-mail me at subzro21@yahoo.com
Jun 23, 2009 | Radio Shack VGA PC Camera Webcam
Emachine T1220 with only one restore cd...what else can I do?
1 Solution for "When ever i plug my eMachine into my dj system through a usb sound card it hum
Apr 17, 2009 | E-Machines eMachines Desktop PC
Remove the emachine/PC ANGEL RECOVERY SOFTWARE
PC angel isn't installed as such it uses the desktop.ini to load its software.
desktop.ini is used to by windows to customise the view of individal folders in windows.
if you know how go to command prompt
type in;
attrib -h -r -s -a c:\folder\*.* /d /s
( replace c:\folder with the drive/folder of the protected folder )
next type in
del c:\folder\desktop.ini
( Again replace c:\folder with the drive/folder of the protected folder)
Bye bye protection for that folder
Apr 14, 2009 | E-Machines (T2824) PC Desktop
Ethernet controller driver for an emachine t2460
Description Integrated Ethernet Driver File Type Original Driver Version 5.504.613.2002 Operating System Windows XP Driver File Download (1.11 MB)
And here is the support site if you need anything else
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2460
Good luck
Nic
Mar 28, 2009 | E-Machines eMachines Desktop PC
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
T2460
Try flashing the main board,
UNPLUG IT
1.) open it up
2.) locate the battery on the board
3.) remove the battery and the memory
4.) press and hold the Power Button for a few seconds
5.) replace the memeory followed by the batter
6.) plug it back in and give it a go
7.) you will need to enter the setup and load the default settings , follow the onscreen instructions to do this
Jul 12, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
