Question about Samsung RS2630SH Side by Side Refrigerator
My fridge get real hot around the left side - Samsung RS2630SH Side by Side Refrigerator
  • Samsung Master
  • 43,501 Answers
On some fridges the condenser coils go up into the side of the fridge to save space...this is what you are feeling...it is nothing to worry about...
heatman101
Posted on Sep 17, 2010
HOT SPOT IN FRONT DIVIDER BETWEEN FRIDGE AND FREEZER
Greg,
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
Section between refrigerator and freezer extremely hot.
Check your owners manual troubleshooting. See if you find an answer. Please be more specific. Sounds like it's "stuck" in defrost mode, since it uses electrical heating elements to make the freezer coils melt ice off, but only lasts long enough to remove the collected ice. I would guess the unit runs constantly, or cannot maintain temperature. If the defrost cycle is not working there is a timer not working, or relay, or somehow a very rare short in the defrost system.
Feb 18, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge does not seem cold enough. It is maybe 12 years old. Do I need a new fridge
The heat between the doors is normal but not really hot. if sides and between the doors is real hot then you have an air flow problem. Vacuum coils under it and coils by condenser fan. Check your Condenser fan by compressor.
Jul 28, 2013 | Refrigerators
The left exterior side of the Fridge get very hot.
On some units the condenser coils are built just inside the side of the fridge to save space....this will cause the side to become very hot...
heatman101
Oct 25, 2010 | GE Profile PSW26P Stainless Steel Side by...
Around Freezer case is getting real hot to touch. Some food is still frozen but some is getting soft.
This is usually the condenser fan under the fridge accessable from the back behind the cardboard cover. It should be running when the compressor runs.
Sep 03, 2009 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from left/freezer side of fridge that is only 2 mon
your drain is stopped up need to take back panel off and get it thawed out and cleaned out maybe with bleach unless you have like a scunci steamer it works real well to melt the ice and blow the drain out
Dec 31, 2008 | GE Monogram Side by Side Refrigerator
Freezer gets real hot
It sounds like the defrost termination t/stat (located on the freezer coil) and the defrost timer have both been jammed on by the storm. A quick way to check is to locate the defrost timer (every model seems to locate it in a different position) look for a round plastic cover around 15mm diameter inside the fridge or freezer, remove the cover and rotate the timer clockwise until you hear a firm "click" then plug the fridge into the power & see if it starts (some defrost timers can also be located near the kick plate or near the compressor well) if the compressor starts (I'm such it will) replace both of these parts.
Cheers John.
Apr 01, 2008 | Whirlpool 25.2 cu. ft. Side-by-Side...
Samsung RS2630SH Side by Side Refrigerator Logo
310 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
