Question about Samsung Washing Machines
Problem: water supply to washing is slow though water pressure is normal. It takes a long time for water to fill up in the machine. Machine model: WA78D4P/XTL. S No. W105ZCSC03394N Dealer: MGB ELECTRONICS, 383-A, 100 Feet Road, Tatabad, Coimbatore 641012 Purchase date: 06.04.10 My mobile: 9585528389 My residence: 33 Manis Nagar, off Gandhiji Rd, near Kannapa Nagar, Coimbatore 641027
  • Samsung Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 17, 2010
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
The LE error code keeps flashing why?
LE means level error. The water fill timer timed out before there was enough water in the machine to clean the clothes. Try this:
  1. Turn the hot and cold water supply taps, located at the end of the fill hoses, as far as they will go toward the "Open" position.
  2. Move the washing machine away from the wall, and examine the hot and cold water pipes for kinks, twists or other obstructions.
  3. Unscrew the fill hoses at the washing machine, and inspect the small plastic screens inside for signs of an obstruction.
  4. Check the water pressure in your home; a reading lower than 30 psi might cause the fill times to extend beyond the time the washing machine is programmed to wait. Slow flowing faucets and shower heads are a sign of low water pressure.
  5. Call for service.
Apr 20, 2015 | Maytag Neptune Washing Machines
Theres a code "LF" beeping....
Hello there and thank you for choosing fixya
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
  • Slow Fill- low water pressure reduces the speed at which water flows into the machine.
    • Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
  • Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
    • Contact the water company to verify the pressure being supplied to the house
  • Error Codes- LF for long fill or FH for no water detected.
    • A plumber may need to be consulted if the pressure is found to be too low.
May 16, 2011 | Washing Machines
The smart drive 708 on any wash cycles has poor water flow..ie the water seems to be filling up very slowly and the normal wash cycle takes 2hrs
Hi Challe340, Sounds like your machines Inlet solinoid valve that supplys water to your machine may have a clogged internal diaphagm, its quite normal for it to clogg up due to high sediment build up in the water mains over the years and seeing that the machine is a smart drive 708 it probly hasnt had inlet replacement in it entire life. As for the normal wash cycle taking so long could be due to restriction in water flow from the faulty inlet valve slowing down the water fill segments in its rinsing cycle stage, hope this help.
May 01, 2011 | Washing Machines
My Kenmore Elite Oasis He washer has a problem with getting stuck when it's in Normal wash at the 17th minute in Rinse where the cold water will not dispense. It goes around slowly for a long time until...
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washing machine fills very slowly even though there is plenty of water supply. Sometimes the water only dribbles in. The worse time is on nthe rinse 2 cycle. Now it stops when the machine gets to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 01, 2010 | Fisher and Paykel (IWL12)
My Fisher and Paykel IW812 washing machine only has a slow fill on the cold water. Tap pressure, hose and inlet screen appear normal. Thoughts?
Yeah if the filters are clear and your water pressure is good replace the inlet valve, i believe on that model the hot and cold come as one assembly which is pretty easy to replace if you take the top off. What happens is part of the valve's inner workings called the diaphragm can devalop a split which'l cause it to fill only slowly
Apr 26, 2010 | Fisher Washing Machines
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Washing Machines Logo
296 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
