Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
How do i graph more than one function at a time?
  • Texas Instru... Master
  • 7,993 Answers
You can draw up to 10 functions on the same graph. However is the Transfrm application has been executed before it will prevent you from graphing more than one functions.
Make sure it is kicked out of RAM.
To do so:
  1. Press [APPS]
  2. Scroll down the list of APPS to reach Transfrm
  3. Highlight it and press {ENTER].
  4. The following screen invites you to uninstall or Continue
  5. Select Uninstall and press [ENTER]
Go to Y= editor and enter the functions.
After you enter a function Press [ENTER].
Cursor moves to next line. Make sure the = signs in all previously entered functions are still highlighted light on dark.
If one equal sign is not highlighted, the corresponding function won't be graphed.
Posted on Sep 20, 2010
Hi, I wonder how to use a TI89 to graph a multivariable functions's 3D picture. Thanks.
First you must configure your calculator to perform 3D graphics
Press MODE
1.The first line shown is Graph. Unfold the hidden menu list with the right arrow and choose Graph 5:3D
2. Press ENTER to validate.
Now you must define the surface you want to draw
1. Press the [diamond] key then [Y=] to get a list of function names, the first of which is z1
2. Enter the following function (or your own) z1=(x^3*y-y^3*x)/390
( x cubed times y -y cubed times x) divided by 390.
3 Press ENTER.
Graph the function
Press the [diamond] key then [GRAPH]
The graphing screen displays progress in %. When it is finished you will see a weird sombrero.
Hope it helps
Mar 21, 2011 | Texas Instruments TI-89 Calculator
I have a TI-Nspire Graphic Calculator (Not the CAS.) I had a couple of questions about the calculator. First off, how do I limit the domain on a function that I am graphing. For example, I am graphing y=x...
simply divide the function by the domain you wish.
In your example, you wanted to graph y=x for x>=0.
You should graph the function f1=(x)/(x>0)
To find out when y=900, graph the function in f1, and then graph the equation y=900 (which will be a horizontal line) and use the intersect function to find where they cross. The x-coordinate of the intersection is the solution you are seeking.
Jan 25, 2011 | Texas Instruments TI-Nspire Graphic...
My calculator wont graph more than one function at a time, how can i fix that?
Hi Lexy,
Chances are, your calculator has a program called "Transfrm" on it that is preventing the calculator from graphing more than one function at a time. Luckily this is easily remedied.
1) Turn calculator on and press the "APPS" key.
2) Scroll down (towards the bottom of the list) and find the "Transfrm" program.
3) With the program highlighted, press the "Enter" key.
4) Highlight the "Uninstall" option and press "Enter".
Once the program is uninstalled, the graphing function of the calculator should be working correctly, allowing you to graph more than one function at a time.
Hope this helps :-)
Dec 01, 2010 | Texas Instruments TI-84 Plus Calculator
Can't graph multiple functions
You have used the TRansfrm application. It remains in memory and takes over the graphing responsibilities from the native OS. You must kick it out of RAM (No, that will not delete it from the calculator).
  1. Press [APPS]
  2. Scroll along the list of APPS
  3. Find TRansfrm and point to it.
  4. Press [ENTER]
  5. Select the Uninstall option.
  6. Open the [Y=] function editor and type in the functions (up to 10)
  7. Press Graph.
Apr 23, 2010 | Texas Instruments TI-84 Plus Calculator
I cant graph more than one equation at a time, it only allows me to graph one Y value at a time.
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T0, Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  4. Calculator displays Done
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognoze that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Feb 17, 2010 | Texas Instruments TI-84 Plus Calculator
I can't graph two functions at the same time (in y=) on a TI-84 Silver Edition. Can you help fix that?
You bet I do, provided
1. there are no hardware problems I am not aware of;
2. that you are willing to follow my instructions.
First thing to do before any new type of problem
1. Turn StatPlots OFF : press [2nd][STATPLOT][4:PlotsOff] [ENTER]
Second thing: Clear the statistical lists
2. Press [2nd][0][PGRM] DownArrow to point to ClrAllLists.
3.Press [ENTER][ENTER]
Third thing : Configure the graph type to be FUNCTION graph
4. Press [MODE]. If FUNC (on fourth line) is highlighted. Press [Y=] and start entering the functions.
5. If FUNC is not highlighted, use Down arrow till 4th line, highlight FUNC and press [ENTER]. Press Press [Y=] and start entering the functions.
Fourth thing: Enter function and select them for graphing
1. As you start entering the function Y1=, notice that the = sign becomes highlighted. Press [ENTER] when Y1 is typed in. Make sure the = sign for Y1 remains highlighted as cursor moves to Y2=.
2. Keep entering the functions and verifying that their = signs remain highlighted as cursor moves to another equation.
3. When finished press [ENTER]
4. Look at the graph style for each function: it is a bit of line to the left of each Y. Here is a picture of all the 7 styles.
To set a graph style, highlight the style to the left of the Y, and press [ENTER]. Each time you press [ENTER] you see a new style, in the order shown on picture.
Avoid the style of Y6, it is bubble, and as such will burst and disappear once graph is finished. Avoid also the triangular ones (for Y3 and Y4) they will shade areas of the graph, and may hide other functions.
Fifth thing: Graph Functions.
1. You can press [GRAPH] to see your graphs.
2. If one curve is missing (and you have not set its style to be rhe bubble), it may be due to the Window dimensions.
Sixth Thing: Set Window dimensions and Zoom.
1. Press [ZOOM][6:ZStandard] to use standard window dimensions.
2. If curve still missing, Press [ZOOM][3:Zoom Out] to zoom out so that you may be able to see a bigger range for the functions.
3. If necessary press [WINDOW] and set the Xmin, Xmax, Ymin,Ymax to values of your own.
Dimensions must obey the conditions: Xmin < Xmax, and Ymin < Ymax.
Hope that helps.
5
Oct 29, 2009 | Texas Instruments TI-84 Plus Silver...
I can't graph more than one equation in the y= area of my Ti 84+
The marking that so puzzle you define the type of line (or dots) to represent the graphs. Enter as many functions as there are Y variables.
After entering a function press [ENTER] to jump to the next one.
When finished entering all functions press GRAPH. If you want graphs drawn one after the other, in MODE highlight Sequential (6th line) and press ENTER. If you want graphs drawn simultaneously, in MODE (6th line) highlight Simul and press ENTER. Press 2ND QUIT to return to previous screen . Execute graph again.
Hope itr helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Silver...
How do I do 3D graphs on a TI-89?
Press MODE
1. Press the [diamond] key then [Y=] to get a list of function names, the first of wich is z1
3 Press ENTER.
Graph the function
The graphing screen displays progess in %. When it is finished you will see a weird sombrero.
Hope it helps
Jul 18, 2009 | Texas Instruments TI-89 Calculator
Two graphs at the same time
Here is one particulat gase where two graphs are executed simultaneously, yet you see one, but bo the other.84fef70.jpg When graphs are being executed the one for tan(x) is displayed as a bubble that outlines the variation of the tangente. But at the end, it evaporates, leaving only the sine function.
d17b645.jpg Here is the result.
Hope it helps.
Jul 08, 2009 | Texas Instruments TI-83 Plus Calculator
I cannot plot graph in my Ti 89 graphing calculator
That means one (or more) of the variables you have in your function is not defined. Check to make sure you didn't misspell any variable name. Also, check to make sure you didn't run two variable names together. "ab" is the variable ab, not a times b.
Mar 19, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
80 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
