Question about Buffalo Technology AirStation WLI-U2-KG54-AI 802.11g/b (wli-us-kg54-ai) Wireless Adapter
With WLI-U2-KG54-AI my computer freezes
for some time now i have been having problems with Buffalo Air-Station Wireless-G (WLI-U2-KG54-AI). When I turn my computer I have to wait for 15 minutes before I can use my computer because it freezes - when I unplug Adapter before powering computer, it works fine!
When I bought Adapter it worked fine for some time. In the meanwhile I set-up another user profile on computer, but I am pretty sure it worked okay in the beginning. Thanks in advance.
V.
I had same problem with my Buffalo, my computer freeze after some time I was not working with it,most certainly when I watched movies. You might have a problem with USB power saving, I solved it and it works fine for me now. Go to deviece manager, find USB root hub device, list its properties and at power managment tab, uncheck Allow the computer to turn off this device to save power.Please let me know if it works for you too lakk@azet.sk
Posted on Jun 13, 2008
BUFFALO DRIVER FOR WLI-U2-KG125S
i have had similar problems with another version of wireless keychain... drivers from Buffalo's and other sites would not work for me.. however using the Airnavigator CD image worked like a charm.
try this link - http://www.buffalotech.com/products/wireless/wireless-g-125-high-speed/wireless-g-125-high-speed-keychain-usb-20-adapter
click on Download and scroll to bottom....
Good luck.
Nov 27, 2013 | Buffalo Technology AirStation ...
How do i get a free soft wear for buffalo air station wli-ti-s11g
here is the solution for u friend....the download link is in the below link
http://www.wireless-driver.com/buffalo-wlicfs11g-wli2cfs11-wireless-windows-driver/
1. click on the download link in the above page for the download to start 2. A .rar file will be downloaded 3. extract it 4. run the set up to install it 5. problem solved:-)
"fell free to ask further help friend...am here to guide u based on computers:-)"
Aug 01, 2011 | Buffalo Technology Buffalo AirStation...
I need a diver of wli-u2-kg54-ai for windows 7. thanks!
Go to the product site
http://www.buffalo-technology.com/support/downloads/
and select your product name and download the driver.
Thanks for using FixYa.
May 29, 2011 | Buffalo Technology AirStation...
I have a buffalo airstation WHRG 125 and I have recently purchased a HP dv4 with a broadcom wireless adapter that accepts wireless g/b connections. I have a wireless g network operating and my other HP...
The OS on the computer is vista.
I think you will need to change the advanced wireless settings on the wireless router.
you can try changing the following settings on the wireless router.
Beakon Interval = 75
RTS threshold = 2307
Fragmentation threshold - 2306
Reduce the MTU 1400.
change the wireless channel.
You can also add the network manually on the vista computer.
open network and sharing center ==> manage network connections
If you see your network listed then highlight the network and click remove at the top.
Now click ADD option at the top.
Then select the option add network manually.
enter the wireless network name and security settings of the wireless network and then try to connect.
to change the wireless settings you will need to open the set up interface of the router.
Click Here for more info
Oct 13, 2009 | Buffalo Technology AirStation...
Wireless driver uninstalls itself after restarts
if it's a usb-dongle, the driver's will be reinstalled every time you reconnect the device. the drivers are on your computer, but have to reconnect with the network adapter when it's reconnected. if the problem is the same after a reboot without disconnecting the network adapter, then there is either a problem with the usb-device, or a driver management problem in windows.
if the usb-device works without problem on another computer, the you need to reinstall windows.
Oct 05, 2009 | Buffalo Technology AirStation...
No driver after reboot
Alas, driver to what. It always helps to state device, brand, model, operating system in a query.
Here is some information. No way for me to narrow it to the relevant device. Don't know what that is!
How to Fix Disappearing HP Printer Drivers Disable HP CUE Device Discovery...
Solved Need help Win 7 losing drivers after shut down reboot
https://social.technet.microsoft.com/Forums/windows/en-US/3339d135-ecbf-46d9-9e4f-d1ec187baaa8/windows-7-printers-have-disappeared-printer-spooler-wont-stay-running?forum=w7itprohardware
When Restart My PC My Video Drivers Disappear Graphics Cards
Some versions of Windows 7 have an XP Mode. The driver that ran perfectly under XP may do so there. That Windows 7 Home Premium is 64 bit may be a factor if the vanishing driver ran under a 32 bit XP system.
Aug 28, 2017 | Buffalo Technology AirStation...
Buffalo KG54 lan utility
There should have been drivers with it when you bought it. If not, here's a link: http://www.opendrivers.com/driver/234540/buffalo-wli-u2-kg54-ai-wireless-usb2.0-adapter-driver-1.01.02.0002-windows-98se-me-2000-xp-free-download.html If you install these drivers, your computer should detect the device. You will, though, still need a modem to be able to connect to the internet. I hope this helps, and if not, post back here, Yannick.
Jun 06, 2009 | Buffalo Technology AirStation...
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Sep 19, 2007 | Buffalo Technology Buffalo AirStation...
Buffalo Technology AirStation WLI-U2-KG54-AI 802.11g/b (wli-us-kg54-ai) Wireless Adapter Logo
329 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
