Question about Polaris Pb460 Polaris Booster Pump Replacement Impeller
How do I remove the pb460 booster pump in order to install the new one? Does the water have to be turned off from the pool?
    Novelist:
  • 116 Answers
You are trying to remove the pump so you can replace the impeller correct?
To remove the impeller you do not need to remove the whole pump. Turn off the electric first. Then just remove the several bolts and separate the back half from the front. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them
Posted on Sep 18, 2010
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
Polaris pump water
you can get at pool supply store
Jan 28, 2014 | Polaris Pb460 Polaris Booster Pump...
Brand new motor replaced old pb4. After installation it just hums and does not pump. Before installation it works fine without water going through? Any body know what is wrong?
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Oct 26, 2013 | Polaris Pb460 Polaris Booster Pump...
New polaris pb4-60 booster pump shuts off when polaris recycles, why?
sounds like weak motor the back pressure is overheating the motor replace
Jul 14, 2012 | Polaris Pb460 Polaris Booster Pump...
Just bought a new polaris booster pump (PB4-60) and installed it...the polaris ran for a few seconds and shut off.
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Apr 14, 2010 | Polaris Pb460 Polaris Booster Pump...
Pb460 does not run. Capacitor checks "good". Connections good. I have power to back of motor, but no power to capacitor.
Who checked the cap and how did they check it? If the cap is out the motor will buzz and not turn when started
Aug 04, 2009 | Polaris Pb460 Polaris Booster Pump...
My polaris booster pump will not come on. when i turn it on the motor makes a humming noise but wont start
Does it have a century motor? If so, remove the shaft cover plate at the rear and try rotating the shaft with a very thick slotted screwdriver or substitute until it turns fairly easily. Often some mild oxide develops around components that just needs to be disturbed.
Apr 12, 2009 | Polaris Pb460 Polaris Booster Pump...
Seals are leaking on my PB4-60 pump
o.k. we will call impeller front ok ? take back cover off look at end of shaft slot for screw driver? put screw driver in slot turn impeller off .
Jan 22, 2009 | Polaris Pb460 Polaris Booster Pump...
Polaris Pb460 Polaris Booster Pump Replacement Impeller Logo
238 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
