Question about Video Game Consoles & Games
My xbox will not conekt to the internet throw my pc i have made it so it allows sheering internet but it stell isont working
  • 25 Answers
Microsoft has a customer service line specifically for this kind of problem... the best bet would be to contact them and have someone sit on the phone with you while you run through the steps to connect your Xbox. If this is not an option, try checking your internet options on your PC and make sure that a system link is available and active, then go through the Xbox again and turn the system link off and back on, this should reboot the connection process between your PC and Xbox and allow them to connect properly... all while connected to an active internet connection of course.
Hope this helps :)
Posted on May 17, 2008
MY HEATER BLOW OUT COLD AIR ON MY 19999 CHEVY VENTURE
Hello, You need to open the two breeder valves and make sheer ur getting coolint throw ur hoses. And make sheer you have no air throw your lines.
Jan 27, 2014 | 1999 Chevrolet Venture
Backfire smoke
This could possibly be caused by several things however the most logical and common reason is simply a sheered flywheel key. This will throw the engine out of time allowing it to fire out of sequence when valves are open instead of closed. I hope this helps you and gets you going again.
Oct 01, 2013 | Husqvarna Garden
My disc wont work i left it in my xbox 360 for a few hours after playing it and then it mysteriusly broke
it probably broke becuase you moved the xbox while the game was playing or you put the xbox from lying down to standing up or standing up to lying down this causes the disk to shift inside of it and scratches the disk when it loads up im sorry to hear of that
Apr 23, 2010 | Microsoft Xbox Console
Dont no how to setup my xbox live using a t-mobile dongle in my pc???
Okay, here's what you do. Set up the dongle in your PC so internet is running.
Now Connect your Xbox to your PC with an ethernet cable.
Next Go to Start> Control Menu>Network Connections
Choose your internet of choice
Right click it
Choose properties
Click the Advanced tab
Check "Allow other network users to connect through this computer's internet connection"
Now try connecting to Xbox live. If that doesn't work go to Xbox Live Network settings and test connection.
Hope this helps you
Jan 27, 2010 | Microsoft Xbox 360 Console
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 will not read my disk
do all your disks do this? if so it could be your xboxs reading lense, if not it may just be sheer coincidence the second disk didnt work, this once happened to a friend of mine, exept with gta4
Mar 13, 2009 | EA Sports Video Game Consoles & Games
Cannot connect belkin wireless adapter to my xbox 360 thru my pc
every computer has an ip adress you might have to go to your internet setting and find some thing that says some thing like... internet adress hook up hopefully you keep files on your computer becuase with out your ip adress you might not be able to hook up its sorta like a combination hope it helpes:)
Mar 02, 2009 | Belkin Video Game Consoles & Games
Xbox shows on computer but xbox says pc not listed
Had the same problem found but from the start. Had to reinstall windows and check connectivity before installing norton. Then installed norton and it blocked it. just changed firewall settings so ip matched xbox as an allowed sharing device and it worked ok. But it would not do it before i reinstalled windows. a bit extreme but it worked. Now i can read all but my video files after a week of it working fine.lol
Dec 20, 2008 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
CONNECT XBOX 360 TO COMPUTER
you are only sharing files with your pc to xbox, you cannot connect to the net throught the pc, the xbox has to have connection to a modem/router, or a router itself which is connected to modem.
Aug 21, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
