Question about Uniden BC60XLT Handheld Scanner
What does the key on the bottom row of keys as well as the other four buttons mean they are LIGHT, WX, L/ O, PRI
    President:
  • 2,761 Answers
From your description, it sounds like your scanner is actually a BC60XLT-1, which is different from the BC60XLT. On the "dash one" the key with the key symbol is for locking and unlocking the keyboard to prevent accidental entries. Press and hold it to lock the keyboard (a key symbol will appear on the display); press and hold it again to unlock the keyboard for normal use. The LIGHT key will temporarily turn on the display backlight for night viewing. The WX key switches the scanner to monitoring of the NOAA weather channels. Pressing the WX button will result in scanning until the unit locks on to a weather channel/frequency that's in use of your area. Press the SCAN key to resume normal operation. Pressing L/O key will lockout whatever channel you are listening to. Pressing it again while stopped on that frequency will restore it to normal monitoring. Pressing PRI will set the selected channel/frequency for priority monitoring, causing the scanner to sample that frequency for activity every few seconds, and to lock onto it if activity is detected. Pressing the key again, while that channel is selected, will release the priority function.
For full information on the functions and capabilities of the scanner, as well as detailed information on how to program it, you can download and print the operating manual, free of charge, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on Sep 17, 2010
Boot sequence
During the boot process you will a certain key to press to enter se up usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced bios features press enter you will see the boot order Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? If you are unsure or have made mistakes you can load optimised or failsafe defaults this will automatically set the boot order Hope this helps.
Dec 14, 2012 | Dell Dimension XPS 400 PC Desktop
How do I go into bios to make my primary 1 hard drive found
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or f2 key this will vary depending on your operating system and computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change the first boot device to your hard drive)
Hope this helps.
Nov 25, 2012 | Computers & Internet
How can i change the real time clock....
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
hope it helps
May 05, 2012 | Dell 038HRF GX150 PENTIUM-III SYSTEM BOARD
Dimondmax22 stm3500320as 500MB juper setings for slave?
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
Hope this helps
Jul 29, 2011 | Maxtor Hard Drive
HOW DO YOU SLAVE WD WD800JD HARD DRIVE?
Hope this helps
Jun 20, 2011 | Western Digital wd200jd-20pk 200 GB Hard...
Have a FIC K8-800T Motherboard. Works fine with 1 SATA drive. Does not recognize second SATA Drive if drive is very large
Hope this helps
Apr 20, 2011 | FIC K8-800T Motherboard
How to set it to a secondary slave on an A-Open AK33
Hope this helps
Apr 13, 2011 | MSI (cr52-m black) CD-RW Burner
I have a problem with the wx priorty check staying on and it keeps me from hearing transmissions how do i shut off.
According to manual you can deactivate the Priority function by pressing the PRI key while the scanner is powered ON. Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.freqofnature.com/resources/reviews/manuals/pro96.pdf
Bill B.
Listening in since the 60's
Apr 08, 2011 | Radio Shack Pro-96 Scanner
I can't find the EXP button on my Casio fx-83GT calculator...help?
Your question is slightly ambiguous.
If you refer to the exponential function (power to base e = 2,7182818...), the key sequence is [SHIFT] [ln]. (rightmost button column, two rows below the ON key).
If you refer to a key allowing to enter powers of 10, like in 3,14 x 10²³, see the button labeled
its located in the bottom button row, center column.
Feb 24, 2011 | Casio FX82ES Scientific Calculator
Uniden BC60XLT Handheld Scanner Logo
382 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
