What is the seer rating? - Heating & Cooling
  • 43,501 Answers
To be able to give you that info. we need a make and model number of the unit you are asking about...
Need both the indoor coil model number and the outdoor model number...
heatman101
Posted on Sep 17, 2010
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
I have a RUDD UPNE-042JAZ. How many tons is that?
That is a 3.5 ton heat pump at 13 SEER.
A S.E.E.R. (Seasonal Energy Efficiency Rating) is the rating and performance standards that have been developed by the U.S. government and equipment manufacturer's to produce an energy consumption rating that is easy to understand by consumers. It has a universal formula and conditioning that can be applied to all units and compensates for varying weather conditions.
Basically, the lower the S.E.E.R. rating, the more energy (electricity) is required to produce the desired effect.
Jun 13, 2011 | Heating & Cooling
NO PROBLEM YET, JUST HAD A GOODMAN AIR CONDITIONER INSTALLED MODEL CKL36-IL AND WAS TOLD IT HAD EXCELLENT EFFICIENCY TO FIND OUT THAT ITS A 10 SEER EFFICIENCY RATING WHICH I UNDERSTAND IS THE LEAST...
10 seer was the most efficient for the older generation units and in 1992, it was required that any unit has to have 10 seer or greater. The least efficient seer rating you will find on any new unit will be 13 seer which is a lot better than 10 seer and will save you almost 30% in energy cost. As of lately, they have made units available that are up to 20 seer or more, but they are pricey. I know you said you just had the unit installed, but from the model number, I'm assuming it is an older unit? If new, then it would have at least a 13 seer rating. Hope this answers your questions!
Aug 18, 2010 | Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
How do you find the seer rating on a condenser is it in the model # or Serial #?
Hello my name is Heath it will be my pleasure to assist you. The model number will give you the seer number if its olde between 5 and 10 years its probably 7 to 9 seer if its newer then its probably 10 to 13 seer.
May 22, 2010 | Heating & Cooling
I cannot find the seer rating or tonage of a Goodman air conditioner serial number 9908524497
My books do not go back far enough to get you the Seer rating, it is a 5 ton unit and as the serial number shows it to be a 1999 model, it is probably a 10 SEER unit, maybe a 12 seer, but not likely, but I can tell you that it was manufactured on the 8th week of 1999.
I hope that I have helped, have a great day.
Sincerely,
Paul Gibson
Mar 31, 2010 | Goodman CKL60AR60 Air Conditioner
If installing a GSC140481 condensor with a ARUF486016 air handler is it necessary to change the txv to increase energy efficiency? Can these 2 units acheive a 14 SEER rating?
The real question is, am I going to get 14 seer using the old coil with the new condencer.If it is using r-22 then the old txv should work,but the old coil is proboby rated at 10 seer . since these were never tested together you would probobly see a minimal gain in efficency.Now if it is a matched set(ahri rated) you with definently get you 14 seer.Hope that helps!
Jul 09, 2009 | Goodman Heating & Cooling
Looking for rating
http://www99.epinions.com/specs/pr-Goodman_Split_System_CLJ36AR42_Air_Conditioner
Please rate my response, thank you.
Jun 04, 2009 | Goodman CLJ36AR42 Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
