Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Water leaks from the jet - GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
  • 901 Answers
Check inlet water pressure! If too high this could happen. Regulate the pressure with a hand operated valve. Available in plumbing material shops.
Posted on Sep 17, 2010
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
A heavy water leak as soon as we turn on the jets. Is it one of the jets leaking or something else?
circ pump and booster pumps are different. circ pump is on during filtration cycles aswell as the heating element. booster pumps run the remaining jets. if you are only losing water when the jets are turned on, then start looking under the tub skirt for leaks within the jets and the plumbing
Oct 03, 2013 | Pool & Spa
Hot tub is leaking
How severe is the leak?
Is the water level dropping when the tub is not in use? If so you will need inspect the back (inside the tub) portion of each jet. There is a gasket and nut on the backside of each jet body, these may come loose for crack.
If your leak is only when you have the pump running, your leak could be on the suction or discharge side of the pump. Only leaking when there is water pressure.
A temporary fix is Fix-A-Leak - a water treatment that will temporarily repair any crack up to 1/8". Its no guarantee but might help.
Sep 27, 2012 | Pool & Spa
After the cycle starts, water leaks out of the bottom of the machine and into the basement
I would call for service. many probabilities and none are good. it is fixable but for a diy'er it could get to be a bit much.
Apr 29, 2012 | Frigidaire Professional Series 24 in....
My Whirlpool tub works, except when water goes above jets it is leaking for the motor. Local plummer would not fix it. HELP Thank you
you probably have a jet that is broken. Sounds to me like if the water gets above a certain level the water starts to leak then that is what it tends to be. pumps will leak water when they turn on if the seal inside the pump is worn out.
Dec 20, 2010 | Whirlpool Home
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Jun 18, 2009 | Flotec Corrosion Resistant Shallow Well...
My spa leaks water to just below the adjustable jet nozzles.
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
Dec 10, 2008 | Dream Maker Spas Dream Maker Ez Spa Hot...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
48 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
