Question about Zanussi 27 in. ZGF782C Gas Cooktop
My gas burner is blocked. popping sound would exists when fire is on and oftently fire will be off. I have clean and wash the burner but problems still arise.
  • Zanussi Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Posted on Sep 17, 2010
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
The two left hand burners of the five do not fully ignite around their circumference. On occasion they do ignite but then pop and go out. Does anyone know of a cause/solution for this?
The way you are describing your problem it sound like the gas supple is weak and pops off. On older Ge Profile cooktops things like grease can get stuck in the orifice spud. To get an idea of what Go to you left burner take off the cap and burner head and look into the hole. You will see a gold spud with a tiny hole. This is called the orifice spud. Make sure the hole is not jambed with grease. You can take it off by using a 7/16 driver w/magnetic tip. Look closely and use a tooth pick or paper clip to clean. and reinsert. If you still have a problem then the issue is in the valves itself. national_a_r_0.png
Change out the left 2x valve.
Have a wonderful day and please rate me a "4" if i was helpful.
Dec 13, 2010 | GE Profile JGP636 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
All 4 burners are firing although the knobs are all in the "off" position. I can't get them to stop firing.
Unplug the oven for at least 30 minutes. Plug it back in and see if it stops. If not, the control board has a problem (could be just bad connections).
May 16, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Ignition problems
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
Jan 14, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Gas takes a LONG time to ignite....fix?
Sexy, first make sure that all the electrodes are giving a spark to the burner caps. If they are, I think your problem may exist with the burner ports (holes). There is a main one that is directed to the ignitor. Take a straight pin and clean out any gunk that may be caught in the holes. Then make sure the burner caps are properly cleaned and seated. You can even scruff them a little on the bottom with sandpaper to get a good ground. Give this a shot first....Catriver..post back.
Nov 10, 2006 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Zanussi 27 in. ZGF782C Gas Cooktop Logo
412 people viewed this question
Top Zanussi Cooktops Experts
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
