Question about Sony PlayStation® 3 (60 GB) Console
I have a playstation 3! It was working perectly until this evening! I attempted to turn this on and it had a green light ollowed by a yellowish light, then back to lashing red! I do not know what to do, please help!
  • 4,102 Answers
How to Fix PS3 Yellow Light on Your Own
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 17, 2010
Why wont my ps3 turn on
The problem might have to do with a power thing maybe the power switch i mean maybe the power at your home went down and that causes the PS3 to basically be unusable, what i would recomend is to go and make a diagnostic to your playstation, im not sure where but im sure that if you google it you might find cheap places to see whats wrong with your ps3Good luck!! :D
Nov 29, 2011 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on it turns green then it turns a yellowish-red color then blinks red what do i do?
Yes this sounds like the YLOD - caused when the GPU and the CPU overheat - you can send it in to fix but they will charge you for this. Or you can fix it yourself from home with a good repair guide.
CLICK HERE FOR A GOOD REPAIR GUIDE
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
When I tru to tuen my ps3 on it gets a yellowish
you need to call sony
call them even if your out of warenty
the problem could be several things
1. it has overheated
2. hard drive has messed up
Dec 20, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 does not turn on...
If it s Green, then YELLOW not a lighter shade of green, then red, then you my friend have got the YLOD (Yellow Light Of Death). there are multiple fixes for this. I myself have suffered the YLOD. This fix here is the most popular. Please be careful when attempting this type of fix as you could damage your system further. WARNING!!!!! This method should only be attempted by those familiar with the inner workings of a PC or equivalent. This should not be attempted by those with little to experience with micro electronics. WARNING!!!!!
I take no responsibility for anyone trying this method to repair the YLOD nor does the creator of the video or YouTube.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
My PS3 doesnt turn on.
The yellow light means there is a hardware failure. Your only hope is to contact Sony.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
