Question about Danco Faucet Stem
I HAVE A DELTA FAUCET AND I'M TRYING TO SEE WHAT STEM DANCO MAKES AS A CROSS OVER THE MODEL # OF THE DELTA STEM IS RP24096 THAT IS THE PART #. CAN YOU PLEASE HELP
    Problem Solver:
  • 15 Answers
Order a moen replacement online from
www.plumbersurplus.com/Prod/Delta-Faucet-Company-RP24096.
Posted on Sep 17, 2010
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Need to adjust the water stop for a delta monitor tub faucet with a Danco 10347 replacement cartridge.
you have to disassemble your old faucet by using "Wrenches". than reassemble the new one
Sep 19, 2013 | Danco Faucet Cartridge
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
I have a Danco 9C-23H/C stem for an American Standard shower stem replacement. I'm trying to identify where the friction ring is supposed to be placed. I've seen it in pictures going on the end where the...
there is never a fiction ring at the washer end, sometimes there is a cup shaped part that holds the washer but nothing else so it must be intended to go around the stem
Jun 27, 2010 | Danco Faucet Stem
Where does washer go for 12h-6h/c stem from Danco for faucet?
Is it brass, stainless, plastic or rubber? I think a stainless one might be for the knob screw, I don't think there is one inside, it might just have fallen into the pack. We get weird stuff all the time that doesn't belong. Hope this helps.
May 31, 2010 | Danco Faucet Cartridge
Looking for cartridge for Tuscany Brass Tub Faucet Single Handle appears to be Ceramic Disk Type
While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
Mar 16, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
How does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Apr 08, 2009 | Danco Faucet Stem
Danco Faucet Stem  Logo
425 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
