posted by tlinzay on May 17, 2008
have an old Hoover steam Vac and it will spray the cleaner down but will not **** up the cleaner. The red ball keeps coming up right away. What is the problem?
Comment by tlinzay, posted on May 29, 2008
Thank You for your help, I really appreciate it. That seems to solve the problem for me and getting back so fast.
Best Solution
posted on May 26, 2008
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
Comment by reddevil6, posted on May 29, 2008
u r welcome.
Rating Locked! (?) tlinzay has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Hoover SteamVac Carpet/Upholstery
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
restrictive valve
restrictive valve
moments after starting the vac... Answer This...
when i fill the water
when i fill the water and soap... Answer This...
My carpet cleaner will not
My carpet cleaner will not pick... Answer This...
cant get upholstery part on
I know where part goes but... Answer This...
Hoover Steamvac Model F6020-900...
The upholstry attachment outer... Answer This...
Repair Service
Find Vacuum Repairman Near You:
