Question about Flotec 1/4 Hp Automatic Utility Pump
Flotec FPUS1860A utility sink pump won't stop running
  • 43,501 Answers
Either the float is stuck or the float went bad...
give it a kick and make sure the float has dropped down and is not hung up...
If that don't work then unplug it and replace the float switch...
heatman101
Posted on Sep 17, 2010
I have the 1/3 hp, 115v model. My pump is in my basement and below my utility sink, it pumps overhead then out to the road. It will pump water out, but then will try to keep pumping. Not continuously...
Do you have a check valve on the discharge line going to the street? This would prevent the backup of water back to the pump making it want to come back on. Things you can try, can you make the holding tank under the sink larger so more water need to be present before it comes on? Also have you tried to put a vacuum break on the system? You can make one easy by razing the outdoor discharge pipe two to three feet high just as it comes out of the house, place a upside down "U" at the top that flows into an open larger pipe that take it to the street. This way if you are getting a back flow you will only get the amount of water between the pump and the upside down "U", however if it was me I would be sure there is a check valve close to the pump so a back flow cannot happen, you can get them at your local hardware or pluming store.
Lastly, the float is adjustable in two locations, one is the location of the float when the maximum water level is reached (turns on the pump) and at the level of water where it turns off the pump, giving a buffer area so if there is flow back it takes more to turn the pump on and less to turn it off, try playing with these two levels on the float.
Nov 12, 2013 | Flotec Utility Sink. 1/4 HP Utility Sink...
The pump just started running continously. As soon as the pump "cycles" you can hear water running back into the pump. It is an under sink model and the sink is not running.
These units have a "check" valve on the discharge pipe which is a one way flow valve. If debris or sludge get caught in the check valve it gets held open allowing water to backflow. Remove and clean or replace the check valve.
Jun 17, 2011 | Flotec 1/4 Horsepower Sink Pump System
My flotec well pump will squirt water and then stop . I keep feeding it water slowly but it won;t prime. What should I be doing?
Check for an air leak in your siphon line. It can be very small and totally prevent the pump from priming.
Jun 08, 2010 | Flotec Corrosion Resistant Shallow Well...
Flotec 1/4 Horsepower Sink Pump System slow to drain. Seems clogged on the sink side of the pump. Can I use Drano or clorox or will that damage the rubber and plastic parts int he pump?
hi, draino and all those sorts of products only make it worse they will help the blockage solidify best way is to run hot water through the system even if it is boiling water from the kettle and a little bit of a pump with a plunger should do the trick
May 27, 2010 | Flotec 1/4 Horsepower Sink Pump System
Pump quite working
Start by checking float switch
Jan 09, 2010 | Flotec 1/4 Horsepower Sink Pump System
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Correct placement for Flotec Utility Pump
should be in drain basin to work properly and check that float moves freely.
May 26, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
How to clean a sink flotec pump
It sounds like the float is stuck. Try pulling the wires coming out of the tank(shake them a little) and see if that will free the float and shut the pump off
Kurt
Apr 04, 2009 | Flotec 1/4 Horsepower Sink Pump System
Flotec 1/4 Hp Automatic Utility Pump Logo
600 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
