SOURCE: emachine E627-5583 does it have a built in microphone?
The best way to check is to click on Start menu> right click on Computer/My Cpmputer> Properties> Device Manger and check if the webcam is listed in it. If it is listed then the computer has Web cam.
SOURCE: I forgot the unlock password for hdd what can I
Get a windows password recovery tool,which can easily bypass windows password if you just forgot windows password.
SOURCE: backdoor password for emachines (ACER)
EMachines is owned by ACER and here is what I have on ACER and BIOS password resets
http://www.fixya.com/support/r3894261-remove_bios_or_hdd_password_from_acer
There may be 3rd party companies that advertise a similiar service but I don't have any 1st hand knowledge
SOURCE: emachines by acer/ana/unlock passwordto wifi
Well you just need to reset the password for the Wifi connection.
You can do that following the steps mentioned below.
Log into your router. Set up the password there.
XP
1) Goto Start/Run
2) Type in "cmd"
Vista
1) Click the Start button
2) Type in "command"
Once you are in the command prompt:
1)Type in "ipconfig"
2) In your Internet browser type in "http://" followed by your default gateway (found in the command prompt)
***Example: http://192.168.1.1 (try clicking the link)
3) Login (search online for login info - depends on your router make and model) Usually admin, password ( or admin/admin)
3) There should be a link on the side somewhere. It should have several options like WEP, WPA, in wireless settings etc.
Else you cud just reset the router back to factory settings which will delete the password and you could connect automatically.
Just FYI : Another method is implementing MAC addressing or dynamically assigned IP addresses.
Regards,
Mihir.
