Question about GE Dishwashers
My dishwasher wont put any water into the machine at all.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 17, 2010
The machine runs its cycle but does not drain all the water
only thing i can say its bit un balanced mite be bit high on front use a water level if still wont work put the back legs a mm higher then front
Sep 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Solve Your
I have spent most of the afternoon looking for the float etc. In frustration I upended the machine to look for the inlet hose point, water started pouring out so I put the machine back in the upright position. Now it's filling with water and working again. Maybe there was something in the hose which became free with upending it. Not sure, but worth a try, it worked for me!
Mar 11, 2010 | Tricity Bendix 18 in. DH090 Free-standing...
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
My dishwasher has water on the bottom that wont drain. I poured some Draino on the bottom but it didn't work. So I tried to run it (without dishes in it) and bubbles and water came out onto my kitchen...
**** out the water with a wet vacuum machine. Remove the sump guard and check with you fingers for any obstacles that prevent the draining. **** out the water and anything else from there. Put the guards back.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher is not working now
Ok you need to put white vinegar in the dishwasher to kill the foam. You also need to disconnect the unit take it outside and tip it right back so the water can flow out. if it still wont go then you've burnt something out eg the flood switch or RFI module where the power cord goes inside the machine cheers
Mar 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dish washer not filling with water when put on
There are a few things that can cause this problem, it could be a defective water inlet valve, it's usually located behind the lower kick plate on the left or right hand side of the dishwasher, When the washing cycle is started it sends voltage to the water inlet valve to open which allows water to enter the machine, or it could be a faulty float switch, when water enters the machine the float switch raises up which signals the water inlet valve to shut off, the float switch is located inside the dishwasher at the bottom, you can check the float switch by raising it up and down to see if it's stuck in the up position. Good luck.
Mar 21, 2009 | Dishwashers
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
