Question about Baby Gear
Funsport Play yard
How do i lock the top rails? I pull up at the elbow of each rail, but it does not lock into place. Cannot find a button or anything inside padding to lock.
Just received used one, no instructions available.
  • kevin8754 Jan 08, 2009
    the handle dont lock when i put them up
I had this problem too. Make sure the bottom isn't down when you're putting the walls up they lock when you pull them up.
I was in tears when I finally called my sister-in-law. I hope this helps someone.
Posted on Jan 02, 2009
    Problem Solver:
  • 17 Answers
Sweet... U have no idea what i just went through lol!
Posted on Dec 21, 2009
How to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Apr 16, 2012 | Cosco Juvenile Cosco Funsport Playard
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
How do you disassemble the Cosco Funsport Play Yard?
Steps to disassemble.1) Pull up on the loop in the center.2) Flip the Funsport upside down3) Pick a side and pull the corners up slightly while pushing the center down. Sides can only move up about an inch.4) Press the release catch in the center of the bar.5) Pull the center of the bar up while holding the release catch in. Sometimes you have to wiggle the catch in and out to get it to release.6) Repeat for each side.7) After each side is collapsed squeeze everything together.8) Place the cover on the floor black side down.9) Put the Funsport on the cover with the plastic corners flush with the edge of the cover. The wheels should be sticking out the bottom.10) Wrap the cover around the Funsport and secure the velcro straps.
May 16, 2011 | Cosco Beatrix Potter Playard Crib
Cant lock the end rails of the porta-cot, the two side ones lock in fine but the end ones just fold back down. Its a Jeep Sahara Limited XT playland.
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Feb 06, 2011 | Kolcraft Jeep Sahara Limited Xt Playard
I can't fold up my Cosco Play Yard 05028. Specifically I get all the sides unlocked but they won't fold up into their upright position (i.e., compact enough to get back into the carry bag.
Hi You have to remove the floorboard and pull up on the strap in the center of the floor before you do anything else, then you unlock the long rails followed by the short rails. If the lock won't release pull center strap higher and try again. Hope that helps!
Oct 06, 2010 | Toys
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How do the side rails of a eddie bauer play yard stay up?
I have this the Eddie Bauer Pack & Play too. The directions says it doesn't matter which sides you pull up first but it does... you have to first pull up the 2 short sides, then you can pull up the long sides and push the button on the bottom to get the whole thing secure.
Hope this helps!
Jaime
Nov 17, 2008 | Baby Gear
Play yard assembly COSCO Funsport L-3
for Model Cosco Funs Port Play Yard
Just pull the cord in the middle of the upward and straighten out
each poll one by one. If you have someone that can help you
open the play yard pull lightly up the four sides and while you're holding them up, pulled the middle strip that located inside pull it up it will lock all four sides at the same time.
I don't have childred, but it drove me crazy that I couldn't do this
until my wife said maybe this is how you do it, I tryed it and it worked. I hope this helps everyone. Regards,
Frankie.
Jul 11, 2008 | Cosco Beatrix Potter Playard Crib
Cosco playard playpen
hey guys, wat you have to do is keep the middle of the playpen up, the very middle thenyou lift up all the sides until they click...once all 4 sides have locked you press the middle of the play pen down and put the mat on top :) hope this helps
May 31, 2008 | Cosco Metal Crib
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Baby Gear Logo
426 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
