Question about Yamaha RX-497 2 Channels Receiver
My Yamaha RX-497 bought 3 weeks ago. It was good power and perfect. I did try to connect one set of home JBL(8 Ohm) big speakers and 4 more small speakers( ? Ohms). Then 4 or 5 times system automaticaly main power shutoff when playing. Now volume power change to 1/2 and middle tone is very low volume. Almost bass and treble only. I think I made some damages on system. How could I fix the system.
  • samjang Sep 17, 2010
    Thanks, I have the tools in my home and I am a computerized player piano install man.
    Could I fix by myself ?
    I want to fix by myself. But I am afraid a little bit.
  • 2,427 Answers
Damaged yes... fix yes,, well hopefully,, ok frstly it seems you blew an output IC or a filter.. now i dont have a diagram and basically one isnt needed,, you will need some screw drivers, a soldering iron and some solder..and a multimeter if you have one..
  1. open up the unt (unplug it first)
  2. look at where the speaker's connect you will notice it leads to 4 - 8 huge IC's on heat sinks.. close to the heat sinks are a few capacitors (filters) look at them and pray you find one with an oily surface.. If so remove it by soldering it, take it to the shop and get a new one to solder in place.. and then test the system to make sure it works..
  3. IF not a filter then plug in and turn on the unit.. touch every one of the 4 -8 ic's to see which get HOT!!!!!! very hot,, that one is blown (actually will be more than one) again unsolder them,, get replacements and reassemble..
  4. turn on and enjoy!!..
Posted on Sep 17, 2010
  • Rishi Roshan Ali Sep 17, 2010
    yeah sure its easy just follow the above steps,, no need to check the voltages on the IC's since the bad ones get hot quiclky,, a mere touch will do,, just be sure to take all necessary precautions against electrical shock,, nah it wont kill you (will hurt a horrid bit) and might damage the unit further.. So just be careful wile doing it.. Also look at the diodes and resistors connecting the filters to make sure none aint burnt ..
I want to hook two speakers on each terminal (L/R).
The correct way would be to hook only one speaker to the powered outputs and use PRE-OUT outputs to connect separate amplifier (or active speakers).
For 2 speakers to work connected to the same powered output of receiver, their impedance would need to be high enough. Yamaha receivers officially support impedance >= 4 ohm for front speakers. If you would connect 2 different 8 ohm speakers, the combined impedance could be theoreticcaly 4 ohm, but that depends on many parameters. On low volumes it should work, but could overload the receiver if used for louder volumes.
Also note that the impedance is a function of frequency (specific to every speaker), so for different frequencies the power from receiver would be devided differently between the speakers and the sound would not be good.
Sep 22, 2013 | Yamaha RX-V671 7.1 Home Theater Receiver...
Hello!!! Thanks for letting me ask these nagging questions. I bought a set of six JBL Home Theater Speakers.I did manage to have them connected and working. But I face a dilemma: How do I connect my...
You want to connect the JBL's to the yamaha using standard speaker wire. Get a few HDMI cables and run one from the blu ray to the yamaha and from the yamaha to the tv. To use the JBL's for watching tv, get an optical cable or coaxial cable (either will work) and connect that from the tv to the yamaha and you are all set.
Aug 20, 2011 | JBL Dual 8 3-Way Floor Standing Speaker...
Yamaha RX-V465 switches off when increasing volume beyond -21.0dB
What speakers you have connected? This receiver supports only 6 and 8 ohm speakers (not 4 ohm). Also check if the ohm settings are correctly set in Advanced Setup (in standby press on the front panel STANDBY while holding STRAIGHT button). In this menu check the setting SP IMP. (speaker impedance) if it maches your speakers (6 or 8 ohm).
Disconnect all inputs and also all speakers. With nothing connected, try to increase the volume. If it still will power off, the unit is probably faulty and should be repaired.
If it does turn off only with speakers connected, check the speaker wires and the speakers, the problem will be there.
Mar 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My Yamaha RX-V390 receiver when volume turns up it turns off
Does it display something on LCD? Maybe you have connected speakers with wrong impendance and the receiver is overheating.
Check the impedance of speakers, it should be at least 6 ohm. Also check the receiver manual if it has settings for impendace (6 or 8 ohm).
Feb 01, 2010 | Yamaha RX-V390 Receiver
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I recently bought a RX-V465 receiver and I need to know what type of speaker terminal jacs are present in the receiver so that I can convert my old SONY Home Theater 5.1 speakers (DAV-FX500) which have a...
1 - As you already have it, take it out of the box and look at the back. You should be able to determine the connections from there. It is also in the owners manual.
2 - The receiver only supports 6 and 8 ohm speakers. Do not use 3 ohm speakers with it.
3 - The Yamaha website has instructions on how to check the firmware version and instruction on how to upgrade the firmware.
Oct 06, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Can I mix 6 and 8 ohm speakers?
I would not suggest mixing. Use either 6 or 8 only but i highly suggest not mixing unless it gives the option to set a certain input for a certain Ohm. If you mix your either going to mess up a speaker or the receiver itself.
Jun 01, 2009 | Yamaha RX-V463 Receiver
Can you run 200watt 6ohm speakers on the RX-V490
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Nov 13, 2008 | Yamaha RX-V490 Receiver
Trying to hook up jbl sr4732 speakers the highs are to loud compaird to the bass or lows. im only using a onkio with a 100 watt per speaker.
These JBL speakers are not made for a home stereo reciever. It could be part of the problem.
I do know that they have a high frequency input and a full range input on each speaker.
I am going to guess that maybe you have them connected to the high frequency input.
Are you using 1/4 inch jacks connecting to the input of the speakers?
I don't remember these speakers having a input for wires.
You may have another issue using these speakers with that reciever.
The JBL speakers are 4 ohms each, it is very likely that the onkyo requires 8 ohm speakers.
Look on the back of the Onkyo where the speaker jacks are at and see if it says anything about the minimum impeadance.
The impeadance is the ohms. Most home recievers are not designed for anything less than 8 ohms. Some are, but most are not.
Using 4 ohm speakers on a system that requires 8 ohm speakers can cause damage to the reciever. Mostly at higher volume levels, it will cause the reciever to overheat and shut off, maybe short out a channel. It pulls 2 times the amount of current thru the output transistors as 8 ohm speakers.
Let me know if this helps you or if you need more help.
Jun 18, 2008 | Audio Players & Recorders
Yamaha RX-497 2 Channels Receiver Logo
122 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
