What is c-motech runtime device change - Computers & Internet
  • 1 more comment
  • Michael Rose Sep 17, 2010
    yes its sprint smartview and yes i get it regularly, i have windows 7 home premium on a gateway nv79 64 bit
    yep, the software and the aircard, i have an nv79 gateway with windows 7home pemium and a 64-bit op. sys.
    thanks hmerchant, again you are a grrrrrrreat help!!!!
    Brigadier General:
  • 7,191 Answers
This error message is related to CMOtech, which is a USB wireless modem.
Please let us know whether you have Sprint Smartview software installed in your PC? (Check C:Program Files\Sprint\Sprint SmartView)
Also, let us know whether you get this error message regularly and also the operating system of your computer.
Kindly reply to this post with the details. Thanks for using FixYa.
Posted on Sep 17, 2010
  • AliTech110
    AliTech110 Sep 17, 2010
    Many thanks for the reply.
    To resolve this issue, you will have to uninstall your Sprint Smartview software and then re-install the same Sprint Smartview software.
    Note: After re-installing Sprint Smartview software, you will likely have to reconfigure the TCP/IP settings according to the instructions you received with the software or via Tech Support from your Sprint provider. If you do not have the configuration instructions, kindly contact Sprint customer support before uninstalling the software.
    Hope this solves your problem. For more help and clarifications, please feel free to reply to this post.
    Thanks once again.
I need istructios for a Motech MIC-7S multiimeter
NOTE: SIMILAR meters have SIMILAR setups and uses for each range... so it's fairly safe to say the "instructions" are basically the same for yours and "most".
I saw nothing 'exotic' in the ranges and options... in other words, almost any basic 'Digital Multimeter' will do.
"For model Digital Multimeter MIC-7S, Motech Industries Incorporated; Taipei
Country: Taiwan (Republic of China) Manufacturer / Brand: Motech Industries Incorporated; Taipei Year: 1985 ?? Category: Service- or Lab Equipment Semiconductors (the count is only for transistors) Semiconductors present. Wave bands - without Details Power type and voltage Dry Batteries / 1 x 9 Volt Loudspeaker - - No sound reproduction output. Power out from Radiomuseum.org Model: Digital Multimeter MIC-7S - Motech Industries Incorporated Material Modern plastics (no Bakelite or Catalin) Shape Very small Portable or Pocket-Set (Handheld) < 8 inch. Dimensions (WHD) 80 x 150 x 35 mm / 3.1 x 5.9 x 1.4 inch Net weight (2.2 lb = 1 kg) 0.2 kg / 0 lb 7 oz (0.441 lb) Model page created by Rudolf Nemeth. See "Data change" for further contributors."
Digital Multimeter MIC 7S
Dec 14, 2017 | Computers & Internet
ROOT\LEGACY_QKNFD\0000
To resolve this issue, examine the device manager to see whether the .NET Runtime Optimization Service V2.0.Number_Numberis installed as a device. If the service is installed as a device, you must uninstall the device. Then, run the following command to install the service correctly:mscorsvw.exe -i
To do this, follow these steps:
  1. Click Start, click Run, type DEVMGMT.MSC, and then click OK.
  2. Right-click .NET Runtime Optimization Service V2.0.Number_Number if the device appears, and then click Uninstall.
  3. In the Confirm Device Removal dialog box, click OK.
  4. At the command prompt, run the following command:%WINDIR%\Microsoft.NET\Framework<64>\v2.0.Number\mscorsvw.exe -i
Jul 18, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Runtime error opening webcam a4tech pk-920h
1st You download Webcam Driver.
webcam a4tech After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Apr 13, 2014 | A4tech PK-910H WebCam
Runtime error
Download my Driver After this install the Webcam driver in the system.
Feb 12, 2014 | A4tech PK-635 Webcam
My projector has only just over 200 hours and is now showing a replace lamp message. The hours have also been reset???
The lamp hours might have not been properly reset.
1. Press the "POWER" button so that the projector projects the picture on the wall (projection screen)
2. Press the "MENU" button to show the "MAIN MENU"
Use buttons "F" or "G" and select "OPTION"
3. Confirm this by pressing "ENTER" so that "OPTION" is shown
Using buttons "5 / 6", select "LAMP RUNTIME" (lamp operation counter)
4. Select and press the "ENTER" button for at least 3 seconds
5. The "LAMP RUNTIME" (lamp operation counter) will change to "TIME RESET[POWER OFF]"
6. Turn the device off by pressing "POWER" and unplug the power cord.
Aug 01, 2011 | Panasonic PT-F200NTU Projector
Yesterday, our 61 inch panasonic projection tv showed pink colors on the lighter colors in the picture. This morning it has two large black stripes across the picture. What could this be? We changed the...
You may have not reset the lamp counter after replacing the physical lamp. To do this 1. Press the “POWER” button so that the projector projects the picture on the wall (projection screen)
2. Press the “MENU” button to show the “MAIN MENU”
Use buttons “F” or “G” and select “OPTION”
3. Confirm this by pressing “ENTER” so that “OPTION” is shown
Using buttons “5 / 6”, select “LAMP RUNTIME” (lamp operation counter)
4. Select and press the “ENTER” button for at least 3 seconds
5. The “LAMP RUNTIME” (lamp operation counter) will change to “TIME RESET[POWER OFF]”
6. Turn the device off by pressing “POWER” and unplug the power cord
Sep 09, 2010 | Panasonic Televison & Video
Microsoft Money etc. Sync Problem with iPAQ hx2495b
IT WAS COZ OF UR WINDOWS SO U SHOUL CHANGE UR WINDOS BECOZ UR DRIVER NOT SUPPORT IN UR VISTA WINDOWS SO CHANGE IT
Dec 02, 2008 | Dell Axim X51v Pocket PC
UR SYSTEM GOT THE VIRUS SO NEWLY INSTALLED UR WINDOWS AND INSTALLED LATEST ANITIVIRUS WITH UPDATE.
Oct 05, 2008 | HP iPAQ HX2490 Pocket PC
Runtime error resolution needed
Since our operating system is Vista I suspected it was related to this. I went into properties for the game and changed the compatibility to Windows XP and it is working fine now.
Mar 12, 2008 | Video Game Consoles & Games
Runtime program
Try downloading the latest version of the drivers from Garmins web site. This often solves problems.
Jan 18, 2008 | Garmin Forerunner 305 GPS Receiver
Computers & Internet Logo
3,216 people viewed this question
David Payne
David Payne
