WHEN I TURN MY TV ON ITS WORK FINE ABOUT 20MIN LATER I GET GREEN LINE THOUGHT THE TV AND I CAN NOT PULL UP MY MENU ON IT,WHEN IT COME UP I SEE BLOCK DIFF COLOR.WHAT IS THE PROBLEM THANK YOU AND THE COSTIF POSS.PLEASE
  • 10,515 Answers
Kindly mention the make and model of the TV?
Thanks!!
Posted on Sep 17, 2010
I have toshiba plasma tv 37"it works fine after 20min blings white horizontal lines,what could be the problem?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 28, 2015 | Toshiba Televison & Video
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
May 15, 2010 | Microsoft Xbox 360 Console
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Colored vertical lines still has sound
it could be your signal check your satalight dish it could of broke moved slightely or tv broke or your sky box what ever you have has broke.
Nov 30, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Replaced STK392-110 convergence chips in tv
1) You will need the original remote for alignment...
Note: Do not open set to adjust red line.....
2) Remove lower front speaker grill cover and possibly the
access panel....find RGB focus / screen block...adjust red
focus...................................T.
P.S.remote control part 23306269 $26.90 ...........
Dec 07, 2007 | Toshiba TP50H95 50" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
