Question about HP PSC 1410 All-In-One InkJet Printer
Catridge is not detectet - HP PSC 1410 All-In-One InkJet Printer
    Scholar:
  • 181 Answers
Printer cartridges are very sensitive especially the contact points (gold contact points) and the printer head itself. The only thing you can do is to clean the contact points and the ink head (nozzle) with a soft cloth or a cotton buds wet with a household 70% alcohol. This will soften the hardened ink You can also clean the contact point on the printer itself. Let the alcohol dries up, reinstall the cartridge then power on again. If error persist, buy new cartridges.
Good luck
TedMac
Posted on Sep 17, 2010
My Garmin nuvi 1450 shows only Garmin logo all the time. My PC can not detectet it. It hapend after update map. Please, need help. Thanks
This answer should help you: Garmin Nuvi 1450 Hard Reset
If your GPS is hanging on startup, you can try to factory reset it, which will revert all settings to originals, and usually make it boot again. Then you can re-update the software and maps.
If you aren't able to factory reset the device, it may have permanently failed and be unable to reset at all. It's probably not fixable.
Mar 13, 2014 | GPS
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
Refill ink not detectet.so how solution?
Try taking out ink and turn printer off,,Then turn back on ,,try putin back in ,,reset cpu also,,check for new drivers and help @ lexmark website,,T here very helpful. thanks and goodluck
Nov 18, 2010 | Lexmark Z2320 InkJet Printer
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
I accidently dropped my external and now it is not being recognized by my computer. How can I retrieve all my files?
At Least it should be detecteted by your Machine, if it is not being detected then Game Over.
If it is detected, then we can proceed, you just want to download the Hiren's Boot Disk. Here or Here.
Burn it on a CD or Make your USB Pen Drive Bootable and Copy Disk in it.
There are tons of Data Recovery Application it it, I'v used them many times, they are Efficiet Indeed.
Regards,
Waqar.
Aug 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
HP 2320 problem
For Every New Catridge there is lock on catridge head u must remove to use the catridge...take out the catridge then remove the shipping seal or lock. refer instruction printed on catridge cover.
Jul 07, 2009 | Office Equipment & Supplies
My printer prints but no document is printed on the paper. Yes I have ink
1.remove your catridge wet your catridge head with headcleaner
2. clean your catridge head with tissue paper
3. do this two or three times
4. fix your catridge and take print
Jun 22, 2009 | Epson Stylus C60 InkJet Printer
Will not print black ink
Please check for the catridge..
I think either the catridge is empty on INK or catridge is having problem..
So, replacing with a new catridge will solve your problem..
Jun 12, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
