Question about Nintendo Video Game Consoles & Games
I can't get my wii to turn on - Nintendo Video Game Consoles & Games
  • 83 Answers
If there is power from the pack ( wall transformer) its quite likely the main fuse - these can be repalced if you can solder SMT :-)
Posted on Sep 17, 2010
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
No power to my wii. outlet is good.
Try the Wii in another working outlet just to see if it turns on. If it doesn't then try another AC Adapter in the Wii. If it still doesn't turn on with a new AC Adapter then that means the mainboad is bad inside of the Wii. If the Wii turns on then that means your old AC Adapter is bad.
Jun 04, 2010 | Nintendo Wii Console
The controler lights flash but wont turn on?
Have you tried syncing the Wii remote?
To sync the Wii remote, turn on your Wii.
Then open the back of the Wii remote (where you put the batteries) and press the SYNC button.
Open the SD Card Slot cover on the front of the Wii. Press the SYNC button.
The controller should turn on.
If your Wii remote still doesn't turn on, visit support.nintendo.com, or call 1-800-255-3700 for Wii assistance.
May 20, 2010 | Nintendo Wii Remote Controller
My wii remote turns off when i play a game cube game on my wii and it doesn't turn back on?
that is normal all it means is that your now using a game cube controller to operate your wii. Also, you must manually turn off your wii and reboot your wii to change games.
Jan 18, 2010 | Nintendo Wii Remote Controller
I just put the internet on my wii and now when i turn my wii off the light is yellow, not red, and the area where you put the disc in keeps blinking blue.
This is because you have wiiconnect24 turned on. wiiconnect24 keeps your wii in a standby mode so that you can receive messages when you are not playing the wii. When the disc tray is blinking blue this means you have a new message. If you want to turn wiiconnect24 off go into the wii settings menu then wiiconnect24. If you just want to turn the wii off fully then when you want to turn the wii off hold the power button on the wii down until it turns red.
Dec 30, 2009 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
Wii remote is not turning on
You probably need to re-sync the Wii Remote.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Source: http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Oct 20, 2009 | Nintendo Wii Console
MY WII WONT TURN ON
Perform the Wii 'RESET'.
1. Unplug the Wii for at least 5 minutes.
2. Plug the Wii back in and try to use it again.
Dec 27, 2008 | Nintendo Wii Console
Wii wheel no longer turns
If the Wii Wheel fails to operate, or operates incorrectly, check the steps below before seeking assistance.
• Make sure the Wii Remote is correctly installed in the Wii Wheel.
• Make sure the game you are playing includes Wii Wheel game play features.
• Make sure the lenses on both the Wii Remote and Wii Wheel are clean and uncontaminated with dirt or other
foreign matter.
• Make sure the batteries in the Wii Remote are not depleted.
• Make sure the Wii Remote is synchronized with the Wii console. Review the Wii Operations Manual - System Setup,
for the procedure for synchronizing your remote with the console if you need more information.
• Review the Wii Remote troubleshooting section in the Wii Operations Manual - System Setup for complete
information on troubleshooting solutions for the Wii Remote.
If your Wii Wheel still does not operate correctly after trying the troubleshooting steps, visit support.nintendo.com for
assistance and additional troubleshooting and repair options or call 1-800-255-3700.
Aug 11, 2008 | Nintendo Mario Kart (Wii) for Wii
Video Game Consoles & Games Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
