Question about ASUS M4A785TDM EVO Motherboard AM3 AMD 785G mATX RAID SATA Gigabit LAN (90MIBAD0G0EAY00Z)
I just built a new system and I am having a problem. The motherboard power led lights up but I can not get anything else to start. Any ideas would be welcomed. Thanks
    President:
  • 1,768 Answers
1. You may have an incompatible power supply.
check the spec for you mother board to see if you power supply is adequate to power your new board. If so .........................
2. check your connection to the new mother board.
If *********** board requires a 400 watts power supply then you may not have enough current / voltage to properly power *********** board.
Posted on Sep 17, 2010
My keyboard was struck by lightning. no longer works. tried power supply. any ideas where to start
your computer doesn't power up after storm. does the lights turn on power supply led, motherboard led are they on. are the fans spinning? if its completely dead, the power supply is the place to start. replace with known working power supply if possible. then everything that was plug into it. could of kill one part or the whole system. motherboard or power supply more likely
Aug 25, 2015 | HP PX850AAABBHPLCD 19 L1906 0.294...
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
My dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power supply but it still wont start up, thinking that it may have shorted some thing out i put in a new power...
Verify that the light on the power block is green with the cable only connected to the wall. If the light goes out when it's connected to the PC the your motherboard is bad.
Nov 22, 2009 | Dell Latitude D600 Notebook
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
Power turns on then immediately off
The case shouldn't have anything to do with power getting to the motherboard. Though there should be a switch on the power supply to increase or decrease the voltage move the switch to the other position and see if the machine stays on.
Apr 26, 2009 | HP Pavilion a1630n PC Desktop
Won't boot
power supply isnt putting out enuf power
Apr 25, 2009 | Intel Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Computer won't turn on
check all led's. then make sure your switch is connected to the motherboard properly. if a conection to the switch is loose (which is what it seems) it wont register to start the boot process.
Feb 24, 2008 | Mach Speed (S755) Motherboard
No bootup
there is nothing to be afraid of check the memory card whether inserted corctly in the slot or a faulty memory card
Oct 22, 2007 | Evga (122-CK-NF68-T1) Motherboard
ASUS M4A785TDM EVO Motherboard AM3 AMD 785G mATX RAID SATA Gigabit LAN (90MIBAD0G0EAY00Z) Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
