Question about Weber Genesis? S-310 Propane Grill
HOW CAN YOU TELL WHCH SETTING IS HIGH OR LOW ON THE GENESIS
  • 111 Answers
When you turn the burner on to light high is the setting closest to ignite or closest to off position without being on ignite.
Posted on Sep 17, 2010
How to tell if a diode is bad
Use the diode setting on the DMM meter. The setting will look like an arrow with a line across it. It should read Low (about 550 ohms in one direction and High (or OL) if the leads are reversed, If it reads low in both directions or high in both directions it is bad,
Feb 08, 2013 | Cyberhome DVD Recorder - DVR1600
Where is low side recharge fitting located on 2004 Ford Exxxxxplorr
low side should be on or near the accumulator whch is on passenger side
Jul 10, 2012 | 2004 Ford Explorer
Hi the crockpot controls have erased the settings could you tell me what is hi...low or heat
Most crockpots have only two settings: low and high/heat. Use the high/heat setting for dishes that will cook in 2-4 hours. The low setting is for your "all day" cooking, typically 6-8 hours.
Hope this helps.
Mar 03, 2011 | Hamilton Beach 33141
My 1100lp when burners are on low flame is to low and make squeeking noise and if a slight bit of wind will blow out flame. I cleaned burner tubes and replaced regulator with factory parts will heat up on...
turn off the LP Tank, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tanl valve on very, very slowly, until it's fully open. Light each burner and turn it to high. Wait for the burners to heat up and turn them down gradually to low. If flame height on low has returned to normal, the problem is solved.
If that didn't solve the problem, the air shutters on each burner may need adjusting. Consult the installation instructions that came with the new burners for the proper setting or consult your Owners Manual.
If it's real real cold outside, it's not unusual for the burners set on low to have a problem. The only solution to that is let the grill preheat well, before turning the burners down. Also, grill with the hood closed on low, if it's a windy day.
Hope this helps you and gets you back to grilling again.
Feb 11, 2011 | Weber Genesis Silver A Grill
F stop indicator flashing. unable to take picture
When the f-stop indicator flashes it usually means that the light is either too low or too high for the particular setting. You should be able to fix it by opening or closing your lens or by changing the shutter speed. The viewfinder indication should tell you whether he setting is too low or too high.
Aug 15, 2010 | Nikon D90 Digital Camera with 18-105mm...
Low flame
Try replacing the hose and regulator, easy to do, and not very expensive.
Jul 07, 2010 | Weber Genesis Silver A Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
No manual for my old Crock Watcher by Proctor Silex
The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
Oct 19, 2009 | Crock Pots & Slow Cookers
I have changed to tata indicom (india) and what
tata indicom cdma dont hve gprs setting.....u can use wap to access internet,can u tell me whch model ur using?
Oct 03, 2009 | LG VOYAGER VX10000 Cellular Phone
Cannot get temperature over 300 degrees anymore
It was the regulator bypass.
For details see:
http://weber.com/support/faq/faq.aspx?id=1
Jul 18, 2009 | Weber Genesis Silver B Grill
Weber Genesis? S-310 Propane Grill Logo
41 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
