Question about Keurig Platinum B70 Coffee Maker
Mini pump KPM27H - 12B5 needs replacing. - Keurig Platinum B70 Coffee Maker
    Scholar:
  • 149 Answers
I can tell that your pump is seized. Remove it from the brewer by detaching the cables and the tube, unscrew it from the frame. Remove the 3 black screws & pull off the plastic (It should be 2 layers), Remove the 2 large screws, and make a note on the metal frame indicating which side goes up to the motor.
Put the pump in a jar filled with isopropyl alcohol and shake it violently. Rinse under your sink, repeat. Remove the plastic cover, and spin the metal pin manually with pliers. Hook the pump up to a DC12V transformer to test. If it spins, let it dry, reassemble and put it back in the machine.
Posted on Jan 02, 2011
MY classic 1976 Austin mini tends to over heat when outside temp is over 35c thermostat replaced with a safari one Radiator good WHY???
Maybe the engine cooling pump not work well?
If use flexible rubber impeller in the pump,check the vanes are leak or broken down?
We supply full range raw water pump impellers for outboard and inboard.Our website www.flexible-impeller.com
Normally we can delivery out by FedEx/UPS in 3~5days arrive customer's hand.I hope which can help you:-)
Best regards from Lindong
Jabsco Johnson Sherwood Water Pump Flexible Impellers Outboard Inboard...
Jun 29, 2017 | Mini Cars & Trucks
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit
Jan 07, 2011 | 2003 Jaguar X-Type
Won't pump water through
You need a new pump It's part # kpm27H
Fairly hard to find unless you want around 50,000
May 05, 2010 | Keurig Platinum B70 Coffee Maker
Where is the power steering pump and fan located on a 2003 Mini Cooper? Is this something that I should have a professional install, or easy to do myself?
the power steering pump is located at rear engine under the exhaust manifold and the fan is fitted under the pump, the fan is easy to replace but the pump is a bit hard if you never done before.
Jan 14, 2010 | 2003 Mini Cooper
Mini power steering faults
hi from uk not had much to do with the new style mini but will try to help ? is the power steer pump electric ? or belt driven ? did power steer fail suddenly ? is oil reservoir full what did the garage say the fault was with old pump ? any more info/symptoms would help to advise on possible reason for failure a 2nd time??
Nov 02, 2009 | 2002 Mini Cooper
2003 Mini Cooper S Power Steering Runs constantly with key off.
the pump is also a computer may need a new pump
Jul 21, 2009 | 2004 Mini Cooper
Steering makes a whining noise - where is the fluid reservoir?
the suspect part for a power steering whine is the power steering pump, flush (very important) the system and replace the PS pump..
Mar 30, 2009 | 2004 Mini Cooper
Password
have you gone to the Microsoft website and searched for create a password reset disk?
or follow this link:
http://windowshelp.microsoft.com/Windows/en-us/help/5bf12a40-12b5-4ca8-87c3-7741adbd15841033.mspx
Jan 08, 2009 | Acer Aspire 9300 Notebook
I have a 2004 cooper and i have been told I need to replace steering pump how hard is it to do ?the problem is intermittant has anybody any sugeestions please prenders167@yahoo.com i'm in Houston
I have experienced total loss of power steering. It took about 45 mins to remove the pump and 2 mins to remove the cooling fan. Two bolts that hold the pump in the surrounding frame are accessible from the rear of the frame near the down pipe of the manifold. My problem now is that after bench testing the fan that works ok and a pump that may or may not work I am unsure of where to go. The research I have seen state there are numerous fuse locations associated w/ this car.
Replacing the pump seems to be the easy part just truly diagnosing the problem is another. I am working this afternoon to get to pump working so I will post other findings tonight or tomorrow.
Jul 27, 2008 | 2006 Mini Cooper
Keurig Platinum B70 Coffee Maker Logo
1,041 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
