Question about Dryers
BARREL NOT ROTATING - Dryers
  • 83 Answers
The belt on the dryer drum needs replaced
Posted on Sep 17, 2010
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Insert lead into Paper Mate Logo 4 0.5mm mechanical pencil
Simply grab the top rotating section, and the lower barrel, and pull apart. This will expose a clear tube in the lower section, where the new lead may be inserted, up to 6 pieces max. Then gently push the top back into the lower section.
Sep 24, 2012 | Papermate Paper Mate® Logo 4 Mechanical...
I have a B&D cordless drill - what are the numbered (2-22) settings for on the barrel of the drill?
Those are for the clutch settings , which you can change by rotating the barrel. the lowest setting will give lots of slip, highest is good for drilling (no slip) .
The clutch helps to prevent driving screws too far, in drwall for example.
Hope that helps
Jul 17, 2011 | Drills
Lens will not retract not batteries
Hello
You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
hope it helps, if not take camera to the technician, if so
DO RATE THE SOLUTION
Good Luck
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
CAMERA LENSE WILL NOT RETRACT.
Hello
Good Luck
Jan 02, 2011 | Canon IXUS 80 IS Digital Camera
When u turn on camara it says lens error and shuts off and the lens wont go in
Hello
if so DO RATE THE SOLUTION
Good Luck
Dec 24, 2010 | Sanyo Vpc-s1070w Digital Camera
Cannot close lens
Hello
Good Luck
Dec 22, 2010 | Kodak Easyshare C813 Digital Camera
I have a 2004 range rover and the key wont unlock the door manually. The transponder was dead and i replaced the battery and it still wont work. Please help, im locked out of my truck but have the key and...
did you try to turn the key in the key barrel? is the key rotating accordingly? does it stop? if it doesn't stop rotating then means barrel got damaged and your Remote key FOB lost it's programming before that. so you should have your spare key if this is the case otherwise you'll end up to break 1 of the glasses to have your car opened. let me know more details and i'll come back to you if i can help
May 03, 2010 | 2004 Land Rover Range Rover
Dryer barrel is not rotating
You will only need to replace the shaft if it looks damaged...replacing the wheel is simple but be sure to add some lubricant to the shaft. but the shaft on maytag usual has a nut securing it from the back side of the unit.
Jun 09, 2009 | Maytag Dryers
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Dryer AD55 barrel not rotating.
belt off of motor pulley or the belt is broken
Apr 10, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
