Question about IBM ThinkPad T42 Notebook
Where is the wifi button on a ibm thinkpad - IBM ThinkPad T42 Notebook
    Guru:
  • 382 Answers
Fn F5 is how enable the wireless capability on this computer....
Posted on Sep 17, 2010
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
  • 6 Answers
SOURCE: IBM ThinkPad T20 2647-44U (Adding Mini PCI WiFi Card)
no it will not work.
Posted on Nov 07, 2008
Joed911
  • 4338 Answers
SOURCE: IBM ThinkPad 560X 2640 (PCMCIA WiFi Card)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Feb 07, 2009
SOURCE: Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Posted on Jan 08, 2010
marked
  • 6487 Answers
SOURCE: does IBM THINKPAD type 2652 1.8GHs has wifi cards
This particular model don't have a built in wireless card on it , it only has a Integrated Network Card for wired connection .
So if you want to make this laptop work wireless you need to get a wireless adapter like this adapter from Linksys WPC54G or WUSB54GC so this laptop can be use wirelessly.
Posted on Oct 01, 2010
I cant find the wifi switch on my IBM thinkpad T23 2647
try press Fn+F5 or refer to the manual.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/62p9631.pdf
Dec 29, 2012 | IBM ThinkPad T23 2647 Notebook
I cannot get network connection with my ibm t21 thinkpad .have a wireless router abd my hp laptop is working fi
hi
the T21 has PCMCIA slot , you need a WiFi card (PCMCIA) : i dont believe it has built in or isntalled WiFi card.
Feb 05, 2012 | IBM ThinkPad T21 Notebook
Where is the wifi switch on the ibm thinkpad and how do i fix it
hello dear first you check in the computer BIOS may be disable /enabled so if disable then you enable then its working
if have a button on keyboad then push the button of FN or that key who have a sign of wifi press it
okyyyyy dear by take care
Dec 25, 2010 | IBM ThinkPad T42 Notebook
Dose all ibm have wireless connection in them
No all ibms dont have wifi built in,,check ibm website to see if your model does,,also jus search online ,,,ibm thinkpad a30 2652 did it come with wifi,,should find answers,,thanks,,goodluck
Nov 20, 2010 | IBM ThinkPad A30 2652 Notebook
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
I wat to kno wifi botton for IBM R52
Is there any shortcut, button or swith for wireless or bluetooth?
Nov 01, 2009 | IBM ThinkPad R52 Notebook
Wifi on ibm thinkpad t30
The wireless driver may got corrupted or uninstalled.
Go to Control Panel - System - Hardware - Device Manager - Click on Network Adapters and if the wireless card is listed click on it to see if it is working and enabled. If not then reinstall the wireless driver.
Aug 13, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Mar 10, 2009 | IBM ThinkPad T42 Notebook
Thanks, Joe
Feb 07, 2009 | IBM ThinkPad 560 E Notebook
IBM ThinkPad T42 Notebook Logo
442 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
