Question about Canon PIXMA MX320 Color USB InkJet Printer
I have an error 5200 The green light flashes and the orange alarm flashes.does not print. have tried unplugging the printer. then plugging it back in. Does not work.
    President:
  • 1,961 Answers
This will work
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Posted on Oct 22, 2010
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Error 5B00 trying to get to service mode to reset waste ink code but need to bypass the alarm mode.
    Hello there..
    Here is how you fix this error:
    1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
    alternately, Alarm in orange and Power in green, starting with Alarm LED.)
    4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
    Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
    Time(s) LED indication Function Remarks
    0 times Green (Power) Power off When the print head is not installed, the
    carriage returns and locks in the home position capped.
    1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
    2 times Green (Power) EEPROM information print
    See 3-4. Verification Items, (2) EEPROM information print.
    3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
    >>>> 4 times Green (Power) Waste ink counter resetting
    5 times Orange (Alarm) Destination settings [hth: not applicable]
    6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
    [hth: 7-10 not applicable]
    11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
    14 not used in servicing
    15 Orange (alarm) return to the menu selection,.
    Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
    any changes.
    [hth: if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
    I really hope this can help you.
    Best regards
    Andrea
    Oct 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Printer Problem
    This was not the sollution for my pinter..
    My Magneta is half full and my error led is also blinking 15 times
    I found this service manual for the IP4200 but this methode also doen not solve my error led..
    Is their someone who has the sollution for this strange error?
    selectable.)
    resume/Cancel button. (DO NOT release the Power
    button.)
    Power
    in
    time(s)
    setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
    not installed, the carriage returns and locks in the
    1 time Orange (Alarm) Service test print .
    >>>>>>>>THIS ONE
    4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
    5 times Orange (Alarm) Destination settings After
    entering the destination settings mode, press the
    to select the destination. For detail, see
    "Destination settings procedures" below.
    7 times Orange (Alarm) Reserved
    8 times Green (Power) CD / DVD check pattern
    9 times Orange (Alarm) CD / DVD print position
    correction (horizontal: X direction)
    10 times Green (Power) CD / DVD print position
    correction (vertical: Y direction)
    11 to 13 times Orange, Green, Orange(Alarm,
    Power,Alarm) Return to the menu selection
    14 times Green (Power) Left margin correction Not used
    in servicing.
    15 times Orange (Alarm) Return to the menu selection
    Time(s) LED indication Destination CD / DVD print
    0 times Green (Power) No change of the destination
    1 time Orange (Alarm) Japan Supported
    2 times Green (Power) Korea Not supported
    3 times Orange (Alarm) US Not supported
    4 times Green (Power) Europe Supported
    5 times Orange (Alarm) Australia Supported
    Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    Canon PIXMA MX320 Color USB InkJet Printer Logo
    209 people viewed this question
    old marine
    old marine
