Question about Sony STR-DE635 Receiver
Sony Receiver - (STR-DE635)
Power supply keeps popping fuse (F801). I need a schematic to determine what is the cause. Can you help me?
  • JohnnLou Jun 02, 2008
    We blew out our receiver and need a schematic to fix it, where do I get one?
gman63b
  • 9 Answers
SOURCE: Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
aborcass
  • 2651 Answers
sorry my expertise is in appliances, youl need to repost you question to another tech
Posted on Mar 22, 2008
renosean
  • 492 Answers
SOURCE: receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Posted on Jan 04, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony receiver STR-GA8ES
You can download required service manual from Manual Zone for small fee.
You can buy required parts for the same unit from Part Store.
Posted on Jan 18, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
Where can I get Manual for Sony STR-DE635
Sony has the user manual for the STR-DE635 here: https://docs.sony.com/release/STRDE635.PDF .
I hope this helps.
Feb 04, 2018 | Sony Audio Players & Recorders
WHEN TO TURN SONY STR-DE635 ON AND NO AUDIO OUPUT
Maybe the Preamp driver IC, looks like a car audio ic on the main board.
Often with age the heat generated by the ic will destroy the solder.Makes it look like lava rock in bar-b-que grill. Which
causes an open circuit in the preamp driver to the audio power
stage.
Simply resolder them, most often restores audio. Should have
a bottom removalble cover.
If not, a fuse normally blows if ic or channel is shorted. Check if
display will say Power off, Protect, etc. That means there is a problem with a channel.
Most Sony receivers use darlington transistors, they short easily !!
I am an old school component level service tech, I think I do have a schematic for this model and many others.
Jan 12, 2012 | Sony STR-DE635 Receiver
Have a Sony STR-DE635 that keeps blowing the 2 8 amp fuses in the power supply. disconnected all speakers and powered up with same result. Checked bridge rectifier and (2) 10000 uf caps all are good
Have you checked the rails to ground for shorts. Get hold of a variac as it does make things a lot easier.
Sound like you might have some shorted output devices.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Sony STR-DE835 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Receiver goes into protector mode
Jan 04, 2009 | Sony STR-DE635 Receiver
Sony str-de635
It may need soldering of the display, could also be a bad resistor or transistor in the power supply.
Dec 08, 2008 | Sony STR-DE845 Receiver
I have a older sony STR-DB830 receiver that keeps blowing two fuses labled f801 and f802. They are 125v 8amp. They pop the instant you turn the power on. Something is shorted, but I can't find it. Is this...
hello, i believe that your problem is in the audio output ckt, check all the transistor you have one bad channel (shorted transistors). with a soldering iron disconnect them and check them with a meter.
good luck
caypianan@yahoo.com
Nov 10, 2008 | Audio Players & Recorders
Mar 21, 2008 | Sony STR-DE635 Receiver
Mar 20, 2008 | Sony STR-DE635 Receiver
Led display goes dead
I suspect intermittent 31V supply, filament supply or bad connections on fluorescent display.
Check Q801 31V reg , R802, zener on base of Q801 located on DC board. Inspect all boards for bad solder joints, reflow and tighten pcb grounding screws.
Oct 23, 2007 | Sony STR-DE635 Receiver
509 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
