Question about Maytag MTF2156GEW Top Freezer Refrigerator
Fridge and freezer no longer cools but big black condensor at back still gets warm
  • Maytag Master
  • 43,501 Answers
The compressor can make enough heat if it is locked up to still make that warm...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
Refrigerator and Freezer not cooling
Wayne, lower back panel, the fan in back (condensor) should be running with the compressor. If the compressor is running,( you should be able to hear it) and the condensor fan is not running. Then the condensor fan motor is your problem. Another sign of a failed condensor fan motor is that the divider between the freezer and refer is extremely warm to touch. If the compressor is not running, it could be the compressor relay and overload (PTC) might be shorted. They made a bunch of these, white in color that failed quite often. Check yours out, it will be mounted to the front of the compressor. Take it off and shake it. If it rattles, there's your problem...Catriver.
Jun 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
The middle part of the freezer and the fridge from my samsung is too hot.
hi there, sounds like you need to clean the back of your fridge, dust maybe blocking your vents, causing poor cooling on your condensor
cheers
Nov 16, 2012 | Samsung RS2530BBP 25 Cu. Ft. Side by Side...
Fridge stopped working/ freezer still works great?
the freezer works ok..this is where the cooling unit is..so, if the freezer works ..its not blowing or allowing air to flow into fresh food area..if its missed its defrost..it will not allow air to go into fresh food area and you need to remove panel and defrost coils ..or see if blower is working...check for bad heater or defrost thermostat or what controls defrost ie timer or board
May 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
To cool the compressor?? I do not have a problem, this is just a general discussion question I'm throwing out there. Every fridge I've ever owned, the compressor gets very warm/hot after running. I have a...
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Feb 22, 2009 | Frigidaire FRT15G4B Top Freezer...
Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Nov 24, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Fridge & Freezer not cooling.
Welshons, You want to make sure that the condensor fan is still running. Your evaporator fan, located behind the panel in the freezer should be running too unless you are in defrost. Your compressor should be running, it may have gotten real hot from the condensor fan not operating and is kicking off on overload. Once it cools down it should restart. Your condensing coils should be warm to the touch if the compressor is running. Right behind the temp. controls you will see a hole in the control cover. In that hole is the defrost timer. You can take a flat blade screw driver and turn the notch clockwise slowly to see if you are in defrost. It will click and the freezer fan should start running,(if it's in defrost). Just a gut feeling tells me either your condensor fan is still not functioning right or your compressor is too hot to start. Check the above out and let us know, Catriver...post back.
Oct 16, 2006 | Frigidaire FRT21P5A Top Freezer...
Maytag MTF2156GEW Top Freezer Refrigerator Logo
37 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
