How can I get my optical drive to start reading and writing dvd/cd disks on my compuiter again?
  • 244 Answers
Once the optical driver goes bad, there is little to nothing to do to fix it.
Think on getting a new one.
Sorry for the bad news.
Don't forget to rate this answer if it helps
Posted on Sep 17, 2010
It will not play Verbatim DVD-R disc that I burnt on my computer.
If it can read any other disk, you should burn your disk again because burning process was incorrect. your computer can't recognize the disk. In this case, probably you can't do anything, no way to try to read a bad disk if computer can't even "see" it.
By the way, you should test to read the disk on some other computer.
If happens with ALL your disks, your optical player is defective.
Again test reading with other computer if record was made correctly
As for your device, you should check if worth to repair and decide if repair or replace it.
How to Replace DVD CD Drive in Computer Tower
How To Install Computer CD DVD or Bluray ROM Drive Ep 7
Replace Laptop DVD CD Optical Drive Complete Tutorial
How To Replace the Optical Drive HP Pavilion DV6 Laptop HD
Sep 03, 2015 | Televison & Video
I can't open the DVD door on my Gateway SX2370 and can't find the reset button (pinhole you would stick a paperclip into). Any idea where it is?
Straighten a paperclip & insert it into the pinhole afront the DVD drive until the drive door opens no further. Carefully but firmly pull it open the rest of the way. Some optical disk drives (ODD's) that tend to require this eject method function just dandy as long as there's an optical disk in the drive. So, it might be a good idea to leave one in there until the drive is replaced. For drives that Windows "cannot find," uninstall such ODD's from the Device Manager & run Microsoft's FixIt tool (Fix problems with CD or DVD drives that can't read or write media) for problems with getting a CD/DVD to read/write.
Feb 26, 2015 | Gateway SX2370-US10P Desktop PC
I have a desktop and i was told that i can use a portable super multi drive burn on my computer. ok but it says its for a mini notebook users. i already use it to burn music but it dont let me use it to...
Optical drives vary in their capability:
* read CD
* read CD and read DVD
* read/write CD
* read/write CD and read DVD
* read/write CD and read/write DVD
What capabilities are available on your "Super Multi" drive?
What software are you using to try to create/burn CD/DVD disks?
Dec 20, 2010 | Computers & Internet
It won't see a blank disk or write to it
CD-ROM and DVD-ROM. ROM stands for "Read Only Memory". On the other hand, CD-RW, DVD-RW stand for "Read/Write". So, if the specs of your laptop say that you only have a DVD-ROM, not COMBO or something ending in RW, then you laptop's optical drive is simply not built for writing to discs.
Feb 15, 2010 | Sony Computers & Internet
Dvd will not burn to disc
replace the drive with a standby n see..
..contact ur System Admin/Vendor
Oct 27, 2009 | Compaq Presario 5000 PC Desktop
Latitude C840 wont reconize optical drive in BIOS
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Cd not reading
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Feb 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dell D600 not reading any type of disk
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
