posted by Compufixit on May 17, 2008
I have an RB-22J1A Durabrand wine cooler. After a power surge, it quit cooling. I disassembled it and discovered it was cooled by a die-electric device. After checking the board with my VOM, I found the board put out the required 12 volts. Although the die electric coil reads continuity on my meter, it does not develop any temperature differential upon energizing. I probable need a new die electric device, but am having trouble finding this part. Can you help??
1 Other User Has The Same Problem
Comment by Guest, posted on May 26, 2008
Durabrand wine cooler #RB22J1A sat it in a coorner cabinet moe it won't cool.
Solution #1
posted on Jun 21, 2008
I bought 2 of these wine coolers and both of them ****! You would be better off returning it if you can or putting it in the trash.Both of mine did not keep them cool. At first they worked for about a day and then they stopped. They refrigerate around 70 to 76 degrees and stay there.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GE GSH22SGRSS Side by Side Refrigerator
GE GDS20SBS Stainless Steel Bottom Freezer Refrigerator
GE GSS25JEMWW Side by Side
GE GBS22HCR Bottom Freezer Refrigerator
GE Profile PSS26NGS Side by Side Refrigerator
Can you Help with these Refrigerators problems?
GE Monogram ZISS420NRSS 42" Built-In...
GE GSH25JSTA SS side by side...
Refrigerator not cooling or... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
