FixYa.com
Tags:
T-Mobile Wing? Smartphone
Screen presses wrong buttons
posted by Fixyaking on May 17, 2008
Whenever I press a certain spot on the screen, it would click a totally different place. Lets say i press the start button, it would click the messages part. Or if I press calender, it would go to the start button. I tried to align the screen but that is not helping because the little four way thing would go to all four corners and just go back to the middle. Over and over, im getting frustrated, somebody please help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 18, 2008
Not Rated (0)
sdowney83
Rank:Apprentice Apprentice
Rating: 80%, 3 votes
Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
it does **** when things go wrong with your phone, but with a little patience, all will be well.
Please let me know if this doesn't work :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PDAs problems?
help
Where can i get or buy a start... Answer This...
help
how i can save d files direct... Answer This...
web and walk
i have a web and walk tmobile,... Answer This...
can't sync up
I can't get all of my contacts... Answer This...
T-WING
do u have a free code to unlock... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
