Question about Pioneer DEH-400UB Car CD/ MP3 Player
Where can i just get the face plate and adapter if i already have the head unit?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
Try pacparts.com
Posted on Sep 17, 2010
The face plate on my radio will not work
Check the connections on the head unit and the face plate. use alcohol to clean them. Look for a reset button, and check fuses.
Feb 17, 2014 | Cars & Trucks
2006 NC MX5 Bose 6 stacker replacement/upgrade
Companies like Scosche and Metra make inexpensive dash kits for the Miata that will allow you to use a standard DIN head unit of any kind. They also often make special adapters to allow a standard aftermarket head unit to plug into the special Bose wiring.
Mar 29, 2010 | 2008 Mazda Mx 5 Miata
I have a red light that blinks when I remove the face plate. but no other readouts or indications that I am getting electricity to the face plate. I can get the cd to go in and come out by resetting the...
try taking an eraser and cleaning contacts on both head unit and face plate also check both constant and accesory fuses if you havent allready if thats not the case you may find that its cheaper to buy a new head unit than to replace face
Jan 28, 2010 | Kenwood KDC-135 CD Player
Control head will not power up. I put power to the unit and hear the cd player movement working inside but no control head activity
make sure the face plate is in correctly. This unit has a removable face plate and it could be half way in. Also, check to make sure the little copper contacts are clean.
Dec 02, 2009 | Kenwood KDC-2011S CD Player
Left side of face plate not locking in no contact
Try cleaning the face-plates electrical terminals with small amounts of rubbing alcohol and cotton swabs, also remove the fuses to the head unit then clean the receiving terminals in the same fashion, allowing all to completely dry before attempting to operate.
Good luck
Aduz
Mar 27, 2009 | Lanzar VBD1100MP3 CD Player
Ipod connection
If you got keys that came with it just slide these down the side, if not just take of the face plate and slide to flat headed screw drivers down the side. it wont damage it.
please rate
Feb 21, 2009 | JVC AM FM CD DET FACE CAR STEREO
Removal of face plate on head unit
theres a spring loaded device behind face plate used to kick face out either the spring broke or became un seated
Jan 13, 2009 | Pioneer DEH-P77MP CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Pioneer DEH-400UB Car CD/ MP3 Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
