Question about Janome 6019QC Mechanical Sewing Machine
How do i change the lightbulb on my Janome 6019 sewing machine?
Where is the light bulb located in a Memorycraft 4000?
Posted on Jun 06, 2011
  • 340 Answers
On most sewing machines the light bulb is located inside the faceplate on the left hand side of your machine.
http://www.janome.com/documents/File/ManualFile/6019QC.pdf
The faceplate is part number 17 in this manual.
One that has been removed, the bulb should be visible. You will need to look at the old bulb to see if it a screw type or a bayonet type, in order to replace it with a new one.
If this is not correct try the Janome website for advice, they have a forum and an ask Jan section for problems etc.
http://www.janome.com/index.cfm/LearningCenter/AskJan
http://www.janome.com/fusetalk/forum/
I hope this is helpful to you!
Posted on Sep 17, 2010
How do I sew a buttonhole on Janome 6019
most likely by setting the machine to that function ..rereading the instruction manual would be my first option .
Jul 31, 2015 | Janome 6019QC Mechanical Sewing Machine
What is the correct replacement lightbulb?
Usually when you pull old bulb out on the base it is printed on there might have to look real hard
Jul 12, 2015 | Janome Harmony 2039 Mechanical Sewing...
How do I replace the lightbulb on a Jamome 9000MC? Where is the lightbulb?
I'm pretty sure you just swing open the lamp cover and the bulb will be right there. It just pulls out.
This is a halogen bulb and will be spendy (over $20).
Feb 26, 2015 | Janome Memory Craft 9000 Computerized...
How do I change the position of the needle (right/left) on my Janie 6019 QC sewing machine?
You may only be able to adjust this one or two spaces. When you have the straight stitch selected, try moving you stitch width slide wider. If you needle is in the correct position, you should see it move as you slide the lever.
Sewing Machine Tech
Oct 24, 2013 | Janome 6019QC Mechanical Sewing Machine
Thread dog lever jammed: Janome MC 6600
it's possible that the feed dog lever has come loose or broken
it would be a good idea to have the machine checked
Jun 12, 2012 | Janome Sewing Machines
TYPE OF LIGHTBULB FOR JANOME SEWING MACHINE
try these sites for parts---some of these sites you may have to email
about the part
ebay
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 30, 2012 | Janome Sewing Machines
Changing light bulb on Memory Craft 8000
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Feb 05, 2010 | Janome Memory Craft 9000 Computerized...
Howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Apr 02, 2009 | Janome 6019QC Mechanical Sewing Machine
Need help with automatic buttonhole for my Janome 6019. How do I use it?
Right, now I've figured this out :)
Put your button in the holder on the foot - fiddle about with it enough and I'm sure you'll work out how, one bit slides open and then you can close it again to hold the button.
Then fit the foot to the machine - the piece with the button in goes at the back.
Select 2 on the stitch selector, 4.5 on the stitch width and buttonhole on the stitch length.
Using scraps make up a piece of fabric with the same number and construction of layers as your finished garment and do a practice run or three.
You can set the actual feed length using the -.+ control (beside the feed release switch at the front, below the sewing table).
Between button holes you need to reset by turning the stitch selector wheel slightly until you hear a click.
Once you're happy with the method, think you have the settings as you want them and feel you have done enough practice try it for real on the garment.
Note: the button holes come out a bit long - just don't cut down the whole length or you may need to hand sew them tighter.
Mar 03, 2009 | Janome 6019QC Mechanical Sewing Machine
Janome 6019QC Mechanical Sewing Machine Logo
884 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
