Question about Samsung Omnia II I8000 Smartphone
I want to change the Operator Settings under Network Settings
  • 1 more comment
  • joseph45 Sep 17, 2010
    I bought my unit from Singapore and it has 3 phones operators preinstalled. However I am using my phone in another country.
    Its the opeartor settings under the network settings that I am refering to.
    I am refering to the Operator settings under the Network Setting.
  • 567 Answers
Hi
To change the network setting you need to go to Menu/Settings/Phone/Network
You will need to select the automatic for automatic network selection.If you select manual then the phone will search for all available networks and allow you to choose one.
This will resolve the issue you are facing. If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Regards
Posted on Sep 17, 2010
  • Anuj Joshi
    Anuj Joshi Sep 17, 2010
    Hi there
    Please correct me if I am wrong.
    What I have understood is that you are trying to make calls from your phone and currently you are not in Singapore
    To make calls you have following options
    1) you can get a new sim card from an operator of the country where you are present now.
    This will work if the phone is unlocked to be used for other network around the world.
    In case the phone is locked,you need to get in touch with the first operator which was associated with the phone when you purchased the phone and ask the to unlock the phone(this is usually is paid service)
    2) you can use the Singapore operator's sim,provided that operator has partnership with any mobile operators in the country that you are currently visiting.
    You need to also ensure that your Singapore operator has activated "international Roaming" facility on your sim.you need to call your Singapore operator to get the settings.(this service is usually free and need just your authorization)
    In short you have to options,get a new sim from any operator in the country that you are visiting (making calls will be cheaper this way).Or using you Singapore sim with expensive call rates.
    In your phone leave the network settings in automatically detect network mode
    Regards
    Genius:
  • 1,478 Answers
I will advice that any settings that you will like to change on you phone should be through you network service provider, give the customer care of your network service provider a call to work you through the changing of ant settings you will like to make on your phone. The service is free and they will be able to guide and give settings that will work with your phone.
Take care.
My phone looses connection very often. it brings up a message saying your answering modem has been disconnected to please check your settings
Try the following, (may work)
To manually select the network operator to use for data connections
You can also manually select your network operator from Connection Setup's
settings screen. Connection Setup will then reconfigure your device's data
connections settings based on the operator that you selected.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the Connections tab, tap Connection Setup.
3. Select the network Country and Operator you want to use, then tap OK.
Note If you choose a Country and/or Operator that is different from the installed SIM
card network operator, you may not be able to access network services.
4. When prompted to confirm whether you want to configure the data
connection settings based on the selected network, tap Yes.
Connection Setup configures the data connection settings.
5. After the Connection Setup completes the configuration, tap Restart.
May 03, 2011 | HTC HD2 Smartphone
I can send sms, but i can't receive any messages. i have check that in have no sms center in mobile network under the settings. how to solve it?
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Mar 12, 2011 | Cell Phones
Setting time and date on Nokia cell phone
To change the clock settings, press adnanbhatti_4.png and select Applications > Clock > Options > Settings.
To change the time or date, select Time or Date.
To allow the mobile phone network to update the time, date, and time zone information to your device (network service), select Network operator time > Auto-update.
SOURCE
Nov 27, 2010 | Nokia N73 Cellular Phone
How to change network settings with the cellphone nokia 5230?
HI,
Thanks for using Fixya.
To change network Settings,
Go to the Main Menu>Settings>Connectivity>Network.
Then you can change Operator Selection and Cell info display.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jun 01, 2010 | Nokia 5230 Cell Phone
How do i change IP address for network printing
yep!
you mean the ip address of the copier?
it is under general settings key operator mode
here's how to do it:
1. set the machine to copy mode (ready to copy displayed on LCD)
2. press FUNCTION
3. press 1
4. press SET
5. press 9
6. press 000 (as a default key operator password)
7. press 1 and 9 ( 19 )
8. the tcp/ip mode will display
you may press clear to erase the current ip address;
just press the number that corresponds to your desired ip address and asterisk (*) corresponds to dot ( . ); after you input the new ip address dont forget to press SET to save the settings
press STOP TO EXIT
that's it :)
Mar 30, 2010 | Panasonic Workio DP-1820E Copier
Samsung i600 ''BlackJack'' - ''phone off'' problem
go go settings,, network setting,, change the status,
Jan 09, 2010 | Lands Phones
Screen saying limited service
This could mean that you don't have any signal from your network operator, or it could mean that your phone has been disconnected from the network.
Go into your phones settings.
Go to Network > Network Selection Mode
Change this to 'Manual'.
Choose another operator network (not your own).
Then go back to your main screen.
Follow the above step again, but this time choose 'Automatic'.
Turn the phone off and back on, and this should solve your problem.
Hope this helps!
Oct 18, 2009 | Samsung SGH-G600 Cellular Phone
Need to modify the network settings
Next to the display panel is a "custom setting" button. Press this then press key operator button on screen. Log-in with 00000 if it hasn't been changed. Then find either Printer Setting - Network Settings or Network Settings will have its own tab. Then press the IP tab. Once changed press ok, a message will display .....turn off copier then turn back on.
Sep 23, 2009 | Sharp AR-M455N Copier
Network wizard Problem
This is usual problem with HTC touch with Airtel Network.
Seek advise from the airtel GPRS executive in any Airtel office.
Last option is to take it to your HTC dealer for change in software. I'll fix the issue.
Jan 31, 2008 | HTC Touch P3450 Smartphone
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
Samsung Omnia II I8000 Smartphone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
