Question about Mitsubishi WS-65809 65" Rear Projection Television
Attn sd tech i have a code 2 2 how do i repair?
  • 1 more comment
  • gehrig234 Sep 17, 2010
    WHAT IS YOUR EMAIL ADDRESS?
    HELL I CANT READ SORRY
    MY EMAIL IS MILLEDGEJ@AOL.COM
    REALLY APPRECIATE THE HELP
    I ALSO HAVE THE 3D PROBLEM I HAVE A REPAIR KIT ALREADY WILL THE PARTS COME IN THAT PACKAGE TO FIX THIS PROBLEM TOO?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
It means one of the two pico fuses for CONVERGENCE is blown.
I will attach photo of the fuses; they and the two convergence chips this set uses are on the middle circuit board--also a photo of a typical IC.
Parts cost on EBAY will be under 20 dollars.
Instructions tell you everything you will need and exactly how to do the repair.
Give me a email and I will send them free.
If this was helpful rate this solution as very helpful as I do this here for free.
SD TECH
f13ee0f.jpgChips will look like this but have the STK-392-570 ON THEM.
Posted on Sep 17, 2010
Testimonial: "VERY HELPFUL AND FAST TONS OF KNOWLEDGE"
  • 6 more comments
  • SD Tech
    SD Tech Sep 17, 2010
    I am not permitted to give mine out here and not really supposed to ask for yours--it is the easy way to get the information to you
    HOW DO I EMAIL U THEN?
  • SD Tech
    You will have to look to see if the pico fuses are included, the kits are way too expensive--On ebay you could have got everything need for under 25 dollars.
    im sure i am learning this the hard way lol
    can u email directions please and is it fairly easy for a novice or am i going to screw something else up doing either of these repairs? lol
  • sclyon Oct 11, 2010
    Mitsubishi W65809 - TV suddenly will not turn on - green light for 2 seconds and then turns off. Did self check and found 2 blinks pause 1 blink. What does that mean and how to fix?
  • Cari Conger-Eldeen Dec 27, 2010
    This was very helpful to me in that it pointed me in the correct direction. I found the instructions on how to get the error code on-line as well for the Mitsubishi models:
    1) Turn the tv on and then let it shutdown
    2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
    3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
    This will commonly be one set of blinks followed by a short pause then another set of blinks.
    This will repeat around five times.
    1 - 2 = no error detected
    2 - 1 = X-ray protect (high voltage or beam current)
    2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
    2 - 3 = Deflection protect
    2 - 4 = Vertical protect
    BTW, the full kit is here:http://www.tvrepairkits.com/xcart/home.p... (more expensive, but complete). And the instructions were here:http://www.tvrepairkits.com/tips/272-mit...
  • Touraned Jan 03, 2011
    Please send instructions on how and where to change pico fuses and convergence chips.
    Thanks, Ed Tourangeau
    touraned@bex.net
Mitsubishi WS-A55 with a 2-3 error code
SD Tech - I have the error code 22 on my WS-A55. Power light comes on and then quickly shuts off. Looked at circuit board - there was greenish "gunk" on two of the electronic parts on the board in the center (behind the speaker grill) in the area labelled R5A62. Would you be so kind as to post repair instructions and the name of parts seller you mentioned above? Thanks!!!
Mar 17, 2013 | Mitsubishi WS-48315 48" Rear Projection...
Tip
MITSUBISHI PROJECTION DIAGNOSTIC FEATURE
If you have a Mitsubishi rear projection where the model number begins with WS or in some cases VS and the set turns on for a moment (green light comes on and goes off) Do the self check most models made from 1999 through about 2005 have:
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
This does not apply to sets with a WD model number, they have different codes.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
If you get one, you can post a question in the Free section here attention:
SD TECH AND I WILL TELL YOU WHAT IT MEANS AND MAY BE ABLE DEPENDING ON THE ERROR TO TELL YOU HOW TO FIX IT.
Mitsubishi was one of the first to have this feature so techs could with ease know where to look for whatever was wrong--a time saver and several other companies followed suit.
Again: Post either a free question or a Premium question here Attention: SD TECH and I or some other expert will be happy to assist you.
on Aug 12, 2010 | Televison & Video
Shuts off after turning on code blinks 2 and 2
2,2 is short protection and means one of two pico fuses is blown and the problem is in the convergence circuit.
I am available as a paid question attention SD TECH and have start to finish step by step instructions for this repair in this model.
Instructions tell you everything you will need and exactly how to do the fix.
SD TECH
Sep 20, 2011 | Mitsubishi WS-55809 55" Rear Projection...
ATTn SD Tech: my 65" Mitsubishi keeps blowing the
1,2 means no error found. To confirm turn set off and unplug and and turn back on, when it fails try the self check again.
Where did you buy the replacement fuses? Radio Shack?
Some of these fuses are special and the poor ones which are generic will pop for no reason sometimes; examine original fuse and holder for correct amperage and type of fuse used.
sd tech
Sep 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I would like to get a copy of the instructions to replace or resolder the convergance IC's on a Mitsubishi WT-46807 from SD Tech please thanks, DT
DT? I am becoming famous with these instructions--having done the repair hundreds of times and getting asked the same question here by many people I composed the step by step instructions.
Once you get the instructions all I would ask is you rate them with a vote on this question.
SD TECH
Jan 25, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi medallion 42 inch Tried the self check feature this set has. The power light blinks a two digit error code--like--2 blinks, a pause, 2 blinks..........it will repeat the error code several...
it means one of the two soldered in pico fuses that protect the convergence circuit is blown.
What is actual model number of the set--begins with vs, ws, or wt.
I can tell you what is needed for the repair--2,2 is short protection and 98% of the time it means a problem in the convergence circuit.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 29, 2009 | Televison & Video
Mitsubishi diamond WS-65909 WILL NOT TURN ON BLINKS CODE 2
Are you getting the 2,2 blink code?
If you are I am the one you want to talk to.
I have repaired hundreds of these sets and know them very well.
Let me know and I will assist you.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Televison & Video
My tv clicks on & then clicks off. no pic
When you turn it on and the set goes off---engage the self check this model has:
On the front of the set press and hold BOTH MENU AND INPUT(or device) for at least 5 seconds and RELEASE both buttons.
The front power light should blink a two digit error code: for example------2 blinks, a pause and 2 blinks--this is the most common error and the most easy to repair.
Let me know what error code you find and I will tell you what it means.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 19, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My tv turns on and then turns off about 3 seconds later. Is there a reset?
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Oct 27, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Can't save pics/vids to micro SD card
First apply code *#7370# or *#7780# Format your 2 GB micro SD ohter wise contact mob-ph repairing centre.
Aug 25, 2009 | Nokia 6133 Cellular Phone
Mitsubishi WS-65809 65" Rear Projection Television Logo
446 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
