Kenmore 91601 Compact Refrigerator Logo
Posted on Sep 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plugged in but not working. - Kenmore 91601 Compact Refrigerator
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 17, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835468
Points
101584
The only things to go wrong there are the thermostat and the compressor...
The t-stat can be replaced easy enough but finding one for that is the problem....
if it is the compressor then it is junk cause it will cost more for a compressor then the thing cost ya new...
heatman101
In the trailer plug the running light tab is dead
You will need to follow the wires back to see if there is a break in the wire.
2answers
Bought firestick, tv only has 1 hdmi connection. tv plugged into hdmi. tried plugging tv hdmi connector into splitter, fire stick into tv & vise versa. won't work with both of them plugged in.
This will mean that your TV will only accept 1 HDMI signal through that port meaning a splitter won't work unfortunately.
The only other option is to get an adaptor for another port that you do have spare on your TV, like AV or DVI.
Cylinder 2 not working Daewoo cielo 1.5i 1995
Do you have spark at cylinder 2? If not, check spark plug wire or spark plug. Another possibility is the ignition coil pack (the thing your spark plug wires run in to). Hopefully that is not the issue because they are expensive new. An easy way to check is to pull the spark plug out of the engine then reconnect it to the spark plug wire. Turn the engine over and check for spark at the end of the plug. WARNING: don't touch the plug unless you like pain. You can always buy a spark plug tester. Anyway, this will determine if you have spark problems with this cylinder.
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Best spark plugs for a toyota EE98
you can use what the factory has in the car or you can use ngk plugs,nipondenso plugs.ac plugs work well and have had good luck with champion plugs.these mentioned plugs will work well with your car.make sure you use the correct plug for your car as listed in the plug book which ever manufacture you choose.
Glow plug burn out
DID YOU CHECK YOUR GLOW PLUGS AFTER REMOVING-CHECK EACH ONE MAKE SURE THATS YOUR PROBLEM AND NOT A BAD MODULE IVE GOTTEN A BAD ONE BEFORE THEY SEEM TO WORK FINE BUT DONT LET ENOUGH VOLTAGE OR TO MUCH VOLTAGE TO PLUGS.
The fan works great, but the light does not work?
are they both on the same switch?
have you checked the bulb it self or the socket that it goes into?
have you checked the plug in the fixture for the light? plug the fan into the light socket plug to check and do the same for the light - plug into the fan outlet...
have you checked both the neutral and the hot for the light plug?
Cigarette plug not working
Hi, the plug is kept in place with a nut that fits on the back of the plug. You will need to take the panel out in order to get to the nut. Before you replace the plug, on the back of the plug, you should see a grayish type of washer where the power cable connection is mounted. If you take that washer out, the plug should work again.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
