Screen too dark
The screen is too dark on my Panasonic 61 inch tv
I have a JVC and my screen is getting darker and darker. There is also a blue shadow on people when they are in the frame.
Posted on Sep 05, 2008
How do i install a lamp for a RCA 61 inch HDTV, have the back cover off but cannot locate lamp. Thank You
I am not sure about the RCA but on th Panasonic models the lamp is actually loaded from the front. Check the front panel just below the screen
Jan 04, 2015 | RCA R61WH76 61" HDTV
Panasonic 61 inch projection TV, 2005, PT61lcx65. TV won't power on. Red power button light blinks repeatedly but TV screen and sound don't come on. Waited 15 minutes one time to see if it just took a...
This is a LCD projection could be problems in the LCD blocks. There is one for blue one for green and red.Also make sure the lamp is good and the door is closed right there is a switch there.
Nov 24, 2013 | Panasonic Televison & Video
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
Screen has blurry look to it , won't get sharp
You should clean your optic lens. The least technical method is to remove the screws around the sides and top of the screen frame. You can then gently pull the screen frame and mirror cover apart a couple inches. Stand on a chair and reach in with a soft cloth and gently wipe the dust off the lens. You can leave the TV on for this... it makes seeing what you are doing easier and there is no shock hazard. I hope this was helpful.
Mar 28, 2010 | Samsung HL-R6167W 61" HDTV
my panasonic model PT61G42V screen went flat lined and went blank still has sound, wwhat should i do?
Mar 22, 2010 | Panasonic Televison & Video
Can't get full screen
What does "8 inches on each dark" mean? you can try the format button on the remote and see of this will fix it.
Mar 15, 2008 | Panasonic PT-65WX51 65" Rear Projection...
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
