Question about Husqvarna Partner K1250 Cutoff Saw Air Filter Kit
I have a partner k1250 cut off saw and there is no spark going to the spark plug. The switch is on, and I put a new spark plug in. Do you think it might be the coil. Rich
  • 41 Answers
First make sure the switch is good and the wires are not grounding anywhere this is cheper fix then a coil when the switch is bad
start simple and work up
good luck
pat
Posted on Oct 24, 2010
Change plug an won't start
Make sure you have the correct spark plug for your maching. and Make sure the gap is correct on the spark plug. Look in your owners manual for the correct gap. Check inside the spark plug wire end that connects to the spark plug and make sure the metal part is still in there to make the connection to the spark plug.
Jun 10, 2014 | Husqvarna Partner Gas Powered Cut Off Saw...
When cutting i think the engine is getting hot how to adj the carb
The K1250 only has a low speed adjustment screw, the main jet is fixed, if the machine idles ok there is no other carb adjustment that can be made.
Jan 19, 2013 | Husqvarna Partner K1250 Cutoff Saw Air...
Looking for year made, of a partner cutoff saw k-700,serial number..3440420need it to order parts
The K700 active and active 11 had a t bar on the side of the blade guard which you pull up to adjust it, and the cutting arm and belt guard are held with 13mm nuts, the active 111 had a plastic bracket on the top of the blade guard which you push to move the guard, and the belt guard and arm are held on with 13mm bolts.
Jan 13, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I have a partner k700 was running fine ,and now no spark. any ideas
sounds like the coil went bad or the kill switch wire grounded out
Jun 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
No spark
Hi, first try a new sparkplug if still no spark the ignition module will need to be replaced, regards Phil.
I changed fuel filter ,fuel line to carberator ,rebuilt carberator and adjusted properly put new mixed fuel and coil is new and gets good spark motor has compression motor fires and stops runinng riteaway ...
Are you sure you pump in the unit properly? Some carbs have the gasket against the carb body and some have the pump next to the body. Also check the needle valve for proper operation,and dirt.
Jan 20, 2011 | Husqvarna Partner K1250 Cutoff Saw Air...
Husqvarna Partner K1250 Cutoff Saw Air Filter Kit Logo
365 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ken skalski
rdjagger
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
