Question about Drills
Motor runs but bit will not drill or works sporadically works fine in chipping only mode
  • 43,501 Answers
The gears inside are stripped...time for a major overhaul or the junk pile...depending on whether you want to spend the bucks to fix it or replace it...
heatman101
Posted on Sep 17, 2010
My drill press motor runs fine, belts don't slip, and the chuck spins just like it should until I try to drill a hole. Then the bit stops, but everything else still works like it should. The belts are
Your drill spindal might be freewilling, if it is your not ingaiging the drive. Some drill presses have a locking switch and or lever to ingage to make this work.
Dec 02, 2014 | Drills
Broken clutch on Hilti TE-75?
The clutch mechanism needs replacement
Aug 25, 2017 | Drills
Drill overheat
Soap might work. Some use candle wax, bees wax, WD 40. I've prayed silicone on the drill bit. Using moderate pressure and low speed definitely helps, and it is essential to clear out the hole of chips frequently. So drilling in increments works. You drill a little, lift the bit up out of the hole to clear the chips. Also the type of bit used is a factor in drilling efficiency: wood boring bits are a good choice. Forstner bits are excellent, and spade bits are just OK. Hope this helps....
Oct 15, 2013 | Drills
My impact drill runs fine, but the working end does not turn.
If the motor is spinning but the bit isn't you have one of two problems. The armature has gear teeth on the end to turn the transmission. If they are stripped out you need a new armature, part number 16-01-3020. If the armature teeth are OK, you need a gear box assembly, part number 14-30-0920. If you don't have a tool repair shop near you to get parts from, you can find them on sites like www.ereplacementparts.com where prices are fair but you do have to pay S&H.
Feb 23, 2013 | Impact Bare-Tool Milwaukee 2650-20 18-Volt...
I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Jul 03, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
I dont have the manel and need to no how to use it
The drill uses bits with the SDS+ connection end. You have three different modes of operation. Hammer drill for drilling into concrete. Drill only for drilling into wood or steel and chip only for chiseling concrete. Now for drill only you would have to change out the chuck for a jacolbs style.
The bits just snap in the chuck. To remove the bits you just slide the chuck sleeve back and remove the bit. To change the chuck you wolulld place the palm of your hand over the chuck and using your fingers pull the sleeve on the chuck that is near the red housing towards your palm and just pull off the chuck.It will snap back on the same way.
May 20, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Makita cordless dril Model # 6213D 12volt.
I used to pull these drills to bits for a living and all i can say is that if the brushes are intact and not too worn then it should run fine without cleaning the brushes. chances are that the motor has worn out.
Sep 13, 2008 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Drills Logo
151 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
