Question about SINGER 7470 Sewing Machine
How do I get the case open to get something dropped inside.
  • 340 Answers
Have a look at the manual for this machine, it should tell you.
http://www.singerco.com/accessories/manuals.html
Just type 7470 in the search box and click search.
On the next page, appears a list with two options. Click on the free download option to download the full instruction manual.
I hope this is helpful for you!
Posted on Sep 17, 2010
  • wingerx5 Sep 18, 2010
    I appreciate the attempt to resolve my problem however this manual you pointed me to is the same one I received with the machine and is practically worthless.
    I called the singer 800 number. They said after you remove the screws and obvious connections there are special pressure points that are required to open the case. They refuse to provide the information saying that if we went inside the case it violates the warranty. I told him that machine is over two years old and I don't care about warranty but they still would not give me the information. They refused to sell me a repair manual, although the nearest Singer repair place is about 300 miles away.
  • r_thomas_304 Oct 16, 2010
    Wow. Winger: A 'guru' sends you to an operators manual ? I applaud your ability to appreciate that. It seems so obvious (to me) that I hesitate to offer this simple suggestion:
    Pick the (thing) up and shake the (other thing) out.
    Pros: obvious(I hope)
    Cons: may require excessive Ppatience,Ppersistence,and Pperseverance
    may require more strength than you have
    Workaround: Enlist aid of one who has more....P,P,P and or strength than you.
    If this is-has been tried without success I will gladly tell you that the 'secret spots' are often hidden under stick on labels. They are likely to be slots,or holes that a small tool is put through in order to push a 'tab' out of the way of a 'catch'. Not clear? Already fixed? Need more? Please Email rogerthomasDOTsewATgmailDOTcom.
Singer patchwork machine, needle fell down inside machine
Don't panic. The needle is probably somewhere where you can get it. Can you see the needle? Look at the cleaning instructions in your manual for how to access the bobbin area. If you can see the needle, try using tweezers or perhaps needle-nose pliers to grab it. You can also try turning the machine upside down to see if the needle will drop out.
If you can't see the needle, it may have dropped all the way to the bottom of the case. If you can shake the machine, can you hear the needle rattling around? If so, I'd leave it there. As long as the needle sets in the bottom of the case, it's probably not going to interfere with the machine's operation unless movement of the machine (ie carrying it to a class) moves the needle into the mechanism. The next time you have the machine servicedthe technician can remove it.
I was thinking about suggesting using a small magnet to grab the needle, but a magnet near a computerized machine may mess up the computer components. So, that's probably something NOT to do.
Mar 03, 2018 | Singer Sewing Machines
Singer 7466 opening plastic case?
you can remove the rocker switch this will allow you to move the case away which inturn will allow more access
Sep 05, 2008 | Singer 7466 Mechanical Sewing Machine
I have dropped a screw from bobbin plate down inside machine. How can I get it out
Tilt the machine slightly to see whether the screw is rattling around in the bottom of the sewing machine case. I've even turned machines upside down and shook them (be sure to put down a towel or something to stop the screw from bouncing and rolling into places unknown!).
Feb 26, 2018 | Sewing Machines
Dropped needle down bobbin area
Check around the bottom inside the machine. If it is not sticking in the needle plate or stuck in the bobbin area, then it has dropped all the way through. Be sure to remove not only the bobbin, bobbin case, but also the hook if possible. You may be able to tilt your machine or gently shake it and the needle will appear.
Jul 13, 2016 | Janome Sewing Machines
I removed the bobbin winder stopper and the nut or something dropped into case. How can I retrieve it?
You can go to an auto parts store and they have magnets with handles where you should be able to retrieve it.
Feb 02, 2015 | Sewing Machines
Where do I oil my TACSEW T 1718?
Most machines need oil where metal parts connect, interact or rub together. It is useful to first clean any old or gummed up oil away. Varsol or paint thinner is good for that. Wipe it all away, then put a single drop of sewing machine oil, not any other kind, on each spot metal parts interact. Turn the machine over and check for places underneath, see if any doors open on the top or side of the machine, or if you can remove screws to give access to the working parts inside. If you see tiny holes that don't have screws in them, these may be oil ports. If they are above otherwise inaccessible areas where metal meets metal, a drop of oil in one of these is appropriate. Set the machine on a towel or something for a day or two in case it drips excess oil. Best to be very sparing with the oil, one drop per location is usually enough. When done, turn the hand wheel and see if all is moving smoothly. If not, another drop where any part is binding may help. If it won't work after that, you need a repair man, as something may be seized. Never force anything if it's not moving properly, you can break off a gear tooth or damage a lever and parts for old machines are not so easy to get sometimes.
Oct 09, 2014 | Sewing Machines
Bolt under bobbin winder fell inside machine LS-2125i
My brother machine has 2 screws that are under the carry handle, this removes the top piece of the casing and then you should be able to just tip the machine upside down to drop the screw out. Hope this helps.
Jan 21, 2014 | Brother LS-2125 Mechanical Sewing Machine
Replacing a damaged top lid from a viking designer se
Yes it is loose in there on the plastic. The pressure from the other side holds it in place. You could install a small screw if you want to make sure it stays in place.
Dec 23, 2013 | Husqvarna Sewing Machines
Handwheel will not turn
First check for thread tangled in the bobbin area and remove it & any lint and etc.
If it is a top loader you must remove the metal needle plate, if front loader, there will be two black clips holding the bobbin case secure with a retaining collar........as you remove them be careful to note the position and orientation of the bits so when you re-assemble, you know where everything goes......a couple of digi-photos are not a bad idea for this.
If there is no thread jam, the shaft, either upper or lower, may be seized......if you can remove the top and bottom casings, a little penetrating spray (WD40 etc) may work, leave for an hour and try to work it free by hand back and forth gently....sometimes it can take several applications and many days depending on the level of corrosion.
Don't "drown" it in oil, and having something like kitchen towel around inside the carcass to absorb excess and runoff.
NOTE:
If you have a casing that is moulded in 2 sections (front & rear) rather than several panels for top, sides and bottom, DO NOT ATTEMPT to open it, you will spend an age in frustration and probably break the casing, they are the devil to open when you have a service manual and NOT something you want to try at home. If you have the 2 piece case, try spraying inside with the small tube attachment on the can via bobbin winder hole, behind and to the right of the bobbin region and any where else you can get the tube, a couple of quick shots in several locations, go and have a nice cup of tea then come back and check for any movement.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Apr 22, 2008 | Kenmore 15212 Mechanical Sewing Machine
SINGER 7470 Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
