Question about LG Washing Machines
Charging port on a Verizion voyager cell phone is not working properly. you can put in the charger cord but you have to hold it at a certain place and it will charge the phone but if you move it, it quits charging
  • 10,865 Answers
Hello. Your phone charging plug is shot and needs to be replaced. Take it to the phone store and ask them what your options are. They may just give you a new phone. Joe
Posted on Sep 17, 2010
M886 won't charge battery. replaced battery still no charge. charger is good.
Hi Jane, I'm Peter. I have had the same problem and discovered that on certain phones the port where you plug the charger cord into may have a little finger of metal that has been bent down some so it can't connect the charger connector . On mine I had to remove the back of my phone to get a little better view then got a toothpick ( don't use any metal ) and gently pried the metal finger back straight so it could slide properly into position to charge. I hope this helps .
Jan 01, 2015 | Cell Phones
Phone will not charge smoothly. keeps saying full charge unplug but only 25% charged, keeps chirping like a short but cords for charger are new. driving me frickin crazy
It might be a problem with your USB charge port. Make certain that the port is clean and not full of dust and gunk. Also check to make certain that you have the latest software and firmware updates installed. And, of course, try turning the phone completely off, let it rest a bit and then power it back on again. If none of these work, then you know that you have a bad USB port.
Jul 04, 2014 | Samsung Galaxy S 4G Cell Phone
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
For LG enV VX9900 Phone, Silver (Verizon Wireless) My charge port is loose. When I plug in charger it moves and is not snug. It now is so loose that I have try and catch the right spot for contact and...
It is not your battery, as far it is charging when you get the right spot at the charging port.
I advice you change your charging port because it is glaring it cannot hold your charger firmly anymore that why you have to all through the stress of locating where it will charge at the charging port.
Just replace the charging port, you will see it will charge without you holding it.
To confirm that your battery is still very good, you can remove it and place in another phone, if it charge, it means it is good.
Please also try to use the charger to charge another similar phone to see if it will giving you such problem because it could also be that the charger is bad.
Take care.
Apr 14, 2010 | LG VOYAGER VX10000 Cellular Phone
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
The charger port on my lg voyager is frayed. If i buy anew charger port, is it easy to install? i thought it was my battery, so i bought a new one on Amazon. put the battery in and it worked fine. i have...
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
May 27, 2009 | LG VOYAGER VX10000 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Charging Problem
you need to take the phone and ahve the charging port checked out to see if your port needs changing....
Mar 25, 2008 | Samsung SCH-a870 Cellular Phone
Washing Machines Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
