Question about Hardware & Accessories
I need instructions for setting my NOMA timer Model #1600. It is not a plug in type. It is wired into my wall switch.
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: Noma timer Type EMT757-UL instruction manual How
The backup battery is a rechargeable battery located inside the unit and cannot be changed.
When the battery goes bad, the timer needs to be replaced.
Posted on Nov 03, 2010
SOURCE: Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM ET525C Manual
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
Posted on Nov 29, 2010
SOURCE: Require instruction how to program
I show Everflourish EMT 757
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 11, 2011
  • 131 Answers
SOURCE: it didnt come with instructions.
http://waterheatertimer.org/pdf/Everflourish-EMT-757-manual.pdf
This is it. Please rate if this helped you. Thanks
Posted on Apr 17, 2011
Noma indoor digital timer instructions lost
Here is a link that shows instructions for a water heater digital timer. Based off of the model # you stated.
http://waterheatertimer.org/pdf/Noma-052-8853-timer-manual.pdf
Apr 10, 2017 | Computers & Internet
Woods 59744 battery operated in wall timer
59744 is not in-wall timer.
It fits over ordinary wall switch and uses AA or A battery to mechanically open and close switch
http://waterheatertimer.org/Woods-timers-and-manuals.html#59744
Gene
h
Nov 22, 2013 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hi, I have a Noma moonrays 88 watt timer with two buttons on the front and a display from 0 to 9. the top button seems to be a manual/auto switch and the bottom one has a clock symbol, but i can't
1) Copy following link for to identify timer, and possible instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Add comment and say what you discover about setting timer
3) Look on timer, and sometimes the instructions are printed on paper label
Dec 09, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have lost the instructions how to set a noma 7 day timer model N1507
Link show all Woods timers and manuals.
Noma is one name used to market Woods timers
Woods N1507 is also 49565
Woods N1507 manual
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment if this manual does not match your timer.
Dec 06, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
ET525C is UPM timer
UPM ET525C Manual
Nov 28, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Lost instructions on how to set it
If I understand correctly, you have an indoor timer
Your timer is Woods brand. (other brands may program differently)
Your timer has a circular dial on the front. (other types of timers do not have a dial, they has a digital display)
Your timer plugs into the wall -or- it is installed in-wall where a switch goes.
Here is a photo that might help.
To set current time, you rotate dial until is lines up with the triangle shape located on inner dial.
If this is not your type of timer, please answer in return and we'll get your timer going with information that is accurate to your model.
Push pins in and out to control ON OFF functions.
If your timer plugs into the wall, then it will not have the manual override slider switch shown above.
Oct 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
Programming my Noma photoelectric switch
I would like to figure out out to program my NOMA photo electric switch Model Number N 1502
Nov 30, 2009 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Lost instuctions to program Model N1560 Noma outdoor timer
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hardware & Accessories Logo
530 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
