Question about Whirlpool Duet GHW9150P Front Load Washer
My washer keeps reading FH during the wash cycle
  • 83 Answers
It means it can't detect water or that the pressure switch trip is not found--press pause/cancel twice to clear the display
Posted on Sep 17, 2010
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
    The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
    One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
    If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
    Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
    Nov 28, 2010 | Kenmore Washing Machines
    My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
    The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
    Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
    flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
    Press START to continue the cycle from the moment that power was lost
    -OR-
    Press STOP/CANCEL to clear the display and completely cancel the cycle.
    Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washer cycle has stopped during the cycle and is showing FH wondering what the problem is, we can't find the manual
    FH is usually a low pressure warning on the water supply.
    You could try cleaning the small filter in the back of the machine, as it may have limescale blocking it.
    If this doesn't cure it, you may have to just use a cold supply instead, or arrange to have a pressurised hot water feed.
    This usually happens in bungalows and flats without enough hot water pressure.
    Nov 05, 2008 | Whirlpool Washing Machines
    Help with whirlpool awm 8103/1
    Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
    http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
    If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
    http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
    I hope this helps you. If you require additional assistance, please let me know.
    Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
    Kenmore elite front load washer
    look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
    Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    54 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
