Question about Kenmore Oasis HE 27082 Top Load Washer
Keeps popping up code "F1." - Kenmore Oasis HE 27082 Top Load Washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
When I pushed the bake oven button on, I heard a loud pop! I thought a light bulb above my range (microwave oven bulb) blew out. Then F1 came on the range screen. We turned off the power to the range...
The F1 error code means one of two thing;either the touchpad is bad or a relay on the conrtol has shorted out. Well the loud pop and the F1,their is not doubt that a relay on the control has indeed shorted out. The fix for that is to replace teh control
PLEASE NOTE A SHORTED RELAY WILL MAKE THE HEAT ELEMENT TO STAY ON AT ALL TIMES AND THE BREAKER MUST BE LEFT TURNED OFF AT ALL TIMES UNTIL THE CONTROL HAS BEEN REPLACED OR IF LEFT ON THEIR WILL BE A VERY VERY GOOD CHANCE OF THE OVEN/HOUSE CATCHING FIRE
Aug 07, 2011 | Frigidaire Kitchen Ranges
F1 error
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
MY 07 GSX R 6 OCCASIONALL POPS A RED LIGHT CODE THAT READS F1 IF
f1 on gsxr stands for fuel injection, unless bike keeps stalling ignor it.my 04 did it all the time , ithink mainly when in slow moving traffic in the wrong gear.
Sep 01, 2009 | 2007 Suzuki GSX-R 600
I have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire code F1
Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
Nov 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
16 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
