I have just discovered that if you pause the player and then let it shut off on its own then press pause again later to wake up the unit and again it will pick up where you were. Now, I don't know if it uses any battery life when it's sleeping so will just have to experiment there. But the key here seems to be NOT actually turning it off. Turning it off will reset it to song #1 every single time. Which is really obnoxious.
mode: for repeat
10+Album: to change song more than 10 like 11 19 Skip/Search: press one time will go to next song press and hold search the song Play/Pause: start playing song or make it stop Stop : stop the song you are playing Eq/Prog : setting menu Vol+- increase or decrease the sound
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat within current Folder (if any), Repeat Folders (if any), Repeat All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
Whilst the song is playing, press menu. A menu will come up with the first option being Repeat. Press play and another menu will appear. About half way down is repeat one. Click onto it and press play.
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
when the ipod was hanged i was waitintg for half an hour then i just pressed the play/pause button it started to deactivate from the lock then again i pressed the play/pause button it switched off then i charged and i started using ............. anyway i am very happy that you tried to help me through ur premium assistance plan..............can i ask a favor ...........that is can i become a fix ya.com member or an expert!!!!!!!!!!!!!!!11
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Visit this site and download the driver for it and reinstall it. Thats all that is wrong. http://www.opendrivers.com/company/27302/iriver-free-driver-download.html
