Question about Lava Computer DUAL EPP PAR PT-PCI 3X FASTER THAN STD (PAR-PCI-DUAL) Serial Adapter
I have a mercury pvm 800 motherboard using intelceleron 2ghz processor with 512 ram i want to make it faster for games pliz help
When I turn on the power the processor fan does not start but when I disconnect the 12volt four pin power connector the processor fan start but no display in both the state. (865 GVHZboard, 2Ghz pro, 512...
The power supply connector might be not place properly. Check the connector in the motherboard there might be one missing that is not being connected the processor connector located near the processor itself...then check also the connector of the cooler fan...it might not be connected...
If all the things is in place but still the problem is exist. Replace your power supply with new...because there might be a defective component into your power supply which is not enough to supply the entire motherboard...
Sep 19, 2011 | Intel D865GVHZ Motherboard
I have this old laptop and its called a compaq (presario 2500) well yesterday i brought the sims3 game for it because the laptop dosent have internet. When i installed the game it says windows xp has to...
Thanks for using fixya.
My name is Carlo.
Your computer might not pass the system requirements that's why it has an error. Or, you can try installing it one more time and check if it will work. Computers do mess up sometimes.
Here's the system requirement of SIMS 3:
Desktop PC (Windows XP + SP2):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2000+ Processor
RAM: 1 GB of RAM
GPU: 128mb Video Card (GeForce FX 5900 or Radeon 9500)
Desktop PC (Windows Vista + SP1):
CPU: 2ghz Pentium4 Processor or Amd Athlon 2400+ Processor
RAM: 1.5 GB of RAM
Laptop (Windows XP + SP2):
RAM: 1.5 GB of RAM
GPU: 128mb Video Card (GeForce Go 6200 or Radeon 9600)
Laptop (Windows Vista + SP1):
RAM: 2 GB of RAM
Read more: http://pc.ign.com/articles/939/939410p1.html#ixzz10TQHijZi
IF your computer does not pass the system requirement, then you cannot play sims3 in your computer.
I hope this helps. Thank you for using fixya
Please leave your comment and ratings. Thanks
CARLO
Sep 24, 2010 | Computers & Internet
Not so much a problem but I have an old Dell dimension with an 866 inteleron processor. I have 2 slots for Ram, each with 256 mb totalling 512, my question is can I replace them with 2 512's for 1plus gb...
Yes you can install 2 512 mb RAM for 1Gb in motherboard.But make sure both 512 RAM are same in configuration and frequency it is better you purchase both ram of same company.Then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 23, 2009 | NEC Pentium III , 866 MHz Processor...
More Ram for graphics
You can share the RAM for VGA max of 256 only for some motherboards. On BIOS select the AUTO instead of selecting 128MB share memory.
Mar 24, 2009 | Computers & Internet
Will mercury mother board (pvm7pro 1.0) supports graphic card
first you must check that *********** board has capacity to use 8x graphic card, if you had a spare 2x or 4x graphic card try on it.
send me reply
Dec 01, 2008 | Computers & Internet
Cricket07 and NFS underground not running on my pc
how much memory does your video card have I suggest you add more ram and a bigger memory video card it sound like your computer is using your hard drive as temporary memory
Jul 21, 2008 | Mercury P4VM800M7 Motherboard
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 05, 2008 | Intel P4 3.0 800 MHZ Retail BOX
Who to overclocke my motherboard'z FSB or my processor?
Hello.
It is not save for your system making it work faster by overclocking it.
Some times it works fine just using the right cooling methods, but some times its leads to system freezes, crashes and even to permanent processor damage.
So i advice you to keep that in mind.
If you want to proceed anyway.
- In newest computers you will find an option to set the processor speed to automatic( system recognize the cpu speed) or manually, in the last one you hve to set the RATIO( Processor speed divided by FSB speed), this means:
- The FSB of your P3 Motherbord (133 Mhz) x 7.5(ratio)= 1Ghz
- In older motherboards the speed option is set using jumpers
configuration in the Board, inthat case you will have to use the motherboard manual( some boards have printed tables) to show you the config.
Note: if your motherboard doesn't show you the RATIO you need is because it doesn't support that speed.
Good look.
Jul 04, 2008 | VIA C3, 800 MHz (VIAC3800) OEM / Unboxed...
Lava Computer DUAL EPP PAR PT-PCI 3X FASTER THAN STD (PAR-PCI-DUAL) Serial Adapter Logo
78 people viewed this question
Top Lava Computer Computers & Internet Experts
David Payne
David Payne
Are you a Lava Computer Computer and Internet Expert? Answer questions, earn points and help others
