Question about Maytag MER6772 Gemini Electric Kitchen Range
I am getting error code F1-8, and the stove beeps randomlt and the front panel is not functional?
  • 83 Answers
F-1 is a defective touch pad or clock and 8 is analog/digital problem. the solution for this is to replace the clock and touchpad
Posted on Sep 17, 2010
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
We have the same problem as Kristen with the F68 error on two different Frigidaire FGEF308TNF ranges. Does she have solar panels on her house as we do?
Thank you for your inquiry, Robert Klaum!
I see that your Frigidaire range is displaying an "F68" error code. I am unsure if another member has the same problem due to solar panels. Typically, an "F68" error code means that you have a high voltage condition. This could be an issue with the polarity, supply voltage, or EOC (Electronic Oven Control). I would recommend having a professional technician out to your home for a proper diagnosis to be completed. Best of luck! -Matt
Dec 19, 2014 | Frigidaire Kitchen Ranges
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Electric panel on stove displays
check the sears kenmore site they have info on error codes.
Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
128 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
